Old 12-02-2003, 12:30 PM   #1
djt
Updating PC800-E to 1014?
I want to update my P4C800-E Deluxe to the new BIOS 1014. I have always used the EZ Flash method in the past to do this but the notes for 1014 say not use this method? What are the exact procedures for updating to this BIOS? When I unzip the download from the Asus site I have two files, AFUDOS and P4CED14.ROM. What do I do with these files?
Old 12-02-2003, 12:39 PM   #2
JoeBar
Bite me if u can...
JoeBar's Avatar
Look here.
Asus P5WDG2 Premium rev. 1.02G
Intel Pentium D 920 SL94S Malay @ 4.31GHz cooled by Thermaltake Big Water 745
GeCube Radeon X1900XT combined with LG 1980Q (8ms) 19' TFT monitor
2 x 1GB Transcend DDR2-533 @ 770mhz
2 x 36.7GB Western Digital Raptors Raid 0 | 300GB Western Digital Caviar SE SATA
Creative Soundblaster X-Fi Xtrememusic combined with Cambridge Soundworks Megaworks 550 THX
Asus E616P3 DVD | Asus 1608-P DVD-RW
Thermaltake Kandalf black super tower with 4 x 120mm and 2 x 90mm blue led fans | Chieftec 550W Triple 12V rails - 120mm fan
Old 12-02-2003, 12:51 PM   #3
DrRedD
DrRedD's Avatar
You do this....................
1)Copy those two files onto a floppy disc
2)Create a DOS boot disc - if using XP just insert another floppy and go to Format it and select "create an MS-DOS startup disc" - then hit start and it should take about a minute or so to complete.
3)leave the created startup disc in the floppy drive and reboot your machine.
4)while rebooting hit the delete key on the ASUS splash screen to enter the BIOS so that you can select in the BOOT Priority menu to start up using the floppy drive - save and exit: your machine will/should now start up using the floppy and will start up in DOS mode.
5)once you get the command line A:\ - take the startup disc out and replace it with the one you copied the 2 files onto.
6)type in "dir" then enter (just so that you can see the files are OK and on the disc.
7) the comand you need to type to update the bios is:
AFUDOS /iP4CED14.ROM
hit enter and it will run
once complete use Ctrl-Alt-Delete to reboot your machine
go back into the BIOS if you want to change the BOOT priority order back to what it was (best to select your hard drive for a faster boot time)
hope that helps..............
DrRedD
Old 12-02-2003, 01:07 PM   #4
noell
You can't use EZ Flash but you can use ASUS Update providing you download and install the latest version of ASUS Update. That's V5.22.02
Here's what I did. Went to the P4C800-E Deluxe website. Downloaded P4CED14A.ZIP. Unzip it to a temp folder to get P4CED14.ROM. Ran AUSU Update and selected "Update from File".
Quick, easy and worked great.
noell
System Info
Motherboard: ASUS P4C800E-Deluxe
CPU: Intel Pentium 4 @ 3.2 Ghz
Memory: 2 X 512mb OCZ PC3200 EL DDR Dual Channel
Video: ASUS V9950 Ultra
Sound Soundblaster Audigy Gamer
Power Supply: Antec 380W
Case: Antec Sonata
Optical Drives: CD-RW 52X24X52 & Sony 16X DVD-ROM
BIOS Version: 1014
Operating System: Microsoft Windows XP Pro
HDD: Western Digital Caviar SE 120GB SATA
Old 12-02-2003, 01:30 PM   #5
djt
I just used DrRedD's instructions and everything worked fine. Thanks for the help and quick responses to my problem guy's.
Old 12-02-2003, 01:49 PM   #6
Whammamoosha
Airborne Gadget Snatcher
Whammamoosha's Avatar
I'm willing to update to 1014 as well. In this case I'll use the AFUDOS that comes with the BIOS file.
Question: should I use the /PBNC flag as well or just the /I flag?
Does AFUDOS flash the boot block without the /PBNC flag?
Earthly by birth,
Watery by affinity,
Airborne by imagination,
Cosmic by goal.
Old 12-02-2003, 02:10 PM   #7
Atomic_abx
To ask a strange question, why bother updating the BIOS at all if all is working fine ?
Asus P5K Deluxe WiFi AP , Q6600 @ 3.4 Ghz
4xOCZ DDR2 6400 800 Mhz,BFG 8800 GTS OC 320 Mb, ,Antec 900 Gamers case,Hiper 580 Watt Modular PSU,
Maxtor 320 Gb 16mb cache HDD SATA II,
Old 12-02-2003, 02:56 PM   #8
klamath
klamath's Avatar
Isn't the newer the better? I guess not .. Remember BIOS 1013?
Old 12-02-2003, 03:10 PM   #9
SLM crew chief
We Came We Saw We Folded
SLM crew chief's Avatar
Depending on what version you are running (I'm using the 1010) there are firmware updates for the Promise controller, just for example.
Folding on a CUSL2/TUSL2? Why not..........
The "Old-School Crew"
SLM crew chief, EJD3, SKI, Drufuss, PeterT Your name here
I walk a lonely road
The only one that I have ever known
Don't know where it goes
But it's home to me and I walk alone -- Greenday
Old 12-02-2003, 03:19 PM   #10
SuperFanBoy
i heard that if you don't update bios right after is out you will have 7 years of bad luck and you have to download bios from german ftp so you have it before it is on asus website.
Old 12-02-2003, 07:47 PM   #11
noell
Silly as it may sound, I updated to 1014 get rid of those annoying beeps at boot-up that supposedly were telling me what USB devices were or were not connected.
noell
System Info
Mobo: ASUS P4C800E-Deluxe
RAM: 2 X 512mb OCZ PC3200 EL DDR Dual Channel
Sound: Soundblaster Audigy Gamer
PS: Antec 380W
Case: Antec Sonata
Optical Drives: Sony CD-RW 52X24X52 & Sony 16X DVD-ROM
BIOS Version: 1014
OS: Microsoft Windows XP Pro (SP1)
HDD: WD Caviar SE 120GB SATA
Old 12-02-2003, 10:13 PM   #12
adamw
Can I upgrade directly from 1010 to 1014 or should I do it version by version.
Adam
Old 12-03-2003, 06:53 AM   #13
noell
Each version stands alone and doesn't depend on what came before. So you can ignore the versions between 1010 and 1014 if 1014 is what you want.
noell
System Info
PS: Antec 380W
Case: Antec Sonata
BIOS Version: 1014
Old 12-03-2003, 07:21 AM   #14
E_Phils
I have a Rev 1.02 board
I used Asus Update 5.22.02 from inside of Windows XP.
Went from Bios 1008 to 1011 and then loaded 1014 when it was released.
No issues at all using Asus Update.
Old 12-03-2003, 07:25 AM   #15
Whammamoosha
Can someone answer this one, pretty pleeeeeeeez?
Earthly by birth,
Watery by affinity,
Cosmic by goal.
