Old 03-28-2001, 05:56 AM   #1
Trebuchet
CUSL2 User
Question
I originally posted this on the PIII Overclocking Forum, but got no response. So I thought I'd try it here:
I'm going to be installing Linux-Mandrake 7.2 in my system soon, probably this coming weekend. I'm currently using StuffPCR to overcome the 141 MHz problem in order to overclock to 1102 MHz. Since this is a DOS program, I don't think it will work with Linux even if I first boot into Windows. Does anyone know if there's a Linux equivalent to StuffPCR? (I sure wish ASUS would install this fix in a BIOS update )
CUSL2/ BIOS 1009 (151 FSB)/ PIII 1GHz@1132 MHz Alpha PAL35t/ InWin Q500N/ Antec PP412X/Crucial 512Mb PC133 2-2-2 5/7 Strong/ Maxtor 20G DiamondMax+/ Prophet GeForce DDR 32Mb w/Blue Orb/ NEC MultiSync 70 17"/ SB Live! Value/ Cambridge Soundworks PC Works/ US Robotics 5610/ TDK 12/10/32 CD-RW/ Pioneer DVD-106/ Digital Research LS-120/ Microsoft Trackball Explorer/ Microsoft Internet Pro Keyboard/ Microtek Slimscan C6/ Lexmark Z42/ Saitek Cyborg3D USB/ Windows 98 SE/XP Pro Dual Boot
Old 03-28-2001, 06:56 AM   #2
pointreyes
I would say that your question might have to be posted on LNO. Might want to give them a try.
http://www.linuxnewbie.org
Old 03-28-2001, 06:23 PM   #3
Trebuchet
CUSL2 User
Thanks, I'll check that out. If anyone could tell me just exactly HOW StuffPCR accomplishes it's task, perhaps someone else could write a Linux version of StuffPCR. But nobody seems to know just what StuffPCR does, just that it fixes a problem. (It's probably a prayer to the DOS Gods )
