Old 02-17-2001, 03:56 PM   #1
LW_P3_700E
Exclamation
I am trying to get my triple boot system running Linux Mandrake 7.2 to get access to the internet.
I have tried 3 different network cards that are Linux ready in slot 5 and have had no sucess. I have tried going through my server and also tried a direct cable connection using DHCP.
I was wondering if it is incompatible some how with my setup. I am also wondering if I changed the slot would that help it possibly? It runs fine in WinMe/Win2k.
I have also been online before this way, so I'm puzzled as to why it doesnt work now. I have tried many different things. And reinstalle dit like 50 times.
Anyone know wassup? Please help!
Thnx.
Old 02-18-2001, 04:54 AM   #2
lynx
When it is running in a windows environment I would leave it in the same slot.
As root user you can issue the 'lsmod' command to see if your card driver is loaded
I have a Digital card (tulip driver) , and the output of the lsmod command produces something like this:
tulip 30744 1 (autoclean)
P4T-E;
PIV 1600;
512Mb Dane-Elec RDRAM;
Hercules Prophet III Ti200;
Adaptec2940U2W;
Toshiba DVD Rom;
4x Quantum U2W scsi disks;
Soundblaster128;
Digital NIC;
Adaptec2940U;
DDS2 Tape unit;
Yamaha2100S Rewriter;
Old 02-18-2001, 02:08 PM   #3
LW_P3_700E
Talking
Thanks for the help, but I tried using my 3com and it works now, but I had to change from expert install to custom install in Mandrake 7.2
Im just learning linux anyways. I set it to DHCP and the IP is set from my server running Windows 2000. I like how I have my server (Abit SA6R) running Windows 2000 Server and my client (CUSL2) running a triple boot on a 30 gig IBM ATA100 drive.
WinMe/Win2k/Linux on the CUSL2 rocks now!
