Old 06-10-2010, 10:48 AM   #1
*** Rampage- 3 -Extreme ***
This is my second day of owning the Rampage- 3 -Extreme. I had the R2E now the R3E. The R3E is a different mobo in many ways as I'm discovering. The BIOS is different and better more options. A new learning chore for me. I'm running my cpu i7 920 @ 42mhz, haven't tried higher yet. My memory MUSHKIN RED with red heat sinks looks nice in this mobo. Its 12gigs 6 sticks running default 6-7-6-18. I haven't tried to oc it yet. CPU and ATI video card 5870 are water cooled. Drives are 3x120gigs OCZ SSD's in RAID-O. I may water cool the NB, and change out my water hoses for red ones. At a later time. Also will upgrade cpu when Intel comes out with a cheaper 6 banger cpu. I used Formula 5 silver compound on the cpu and NB. It takes awhile for it to settle in. So in the interim my cpu temps are higher then I like. I'm running OCCT now as I type to see how stable my oc is.......Here are some pic's of my 42mhz oc and temps..I'll be posting more on the R3E as I learn more of the BIOS settings and mobo. If anyone would like to contribute to this thread their welcome, ya hear DBoone.....
Old 06-10-2010, 11:25 AM   #2
Re: *** Rampage- 3 -Extreme ***
Just finished 1 hr CCCT Linpack stable @ 42mhz.....
Hope to see temps drop as Thermal compound settles in.
Here's temp @ idle.....
Old 06-10-2010, 04:51 PM   #3
4+ hrs stable with OCCT linpack @ 42mhz oc on R3E cpu i7 920..
Stopping OCCT @ 5+ hrs stable 4200mhz.......
Old 06-10-2010, 07:28 PM   #4
DBoone
Just call me Dave
DBoone's Avatar
You're doing really well. And your temps are much better than mine. My rig is a little short of radiator but I've been thinking that I probably need to redo the TIM too.
Water cooled rig - Obsidian 800D, Corsair HX750, Sapphire 5570, Asus Rampage III Extreme, Intel Core I7-930, 6GB Corsair Dominator PC3-12800 (DDR3 1600) memory, Windows 7 Pro
Old 06-10-2010, 09:57 PM   #5
Thanks, well having own a R2E has helped with this mobo.
Yeah sometimes changing brands of thermal paste will
help or reapplying the same stuff....
Old 06-11-2010, 07:05 AM   #6
Pentium4
Pentium4's Avatar
Congrats on the the new board Sir Skully That's the exact board I was going to get shortly, however it may have to be put on the hold now, as it appears that my faithful GTX280 is heading to video card heaven
INTEL INSIDE
* Gigabyte GA-Z97X-G7 * Intel i7 4790K * G.Skill 2400MHz TridentX 16Gb DDR3 (10-12-12-31-1T) *
* Samsung U28D590 28" 4K Monitor * Palit GTX780 VGA (967/6010) * Samsung 850PRO 1TB SSD *
* LG CH12LS28 Blu-ray Optical Drive * CM Xornet II Gaming Mouse * Onboard 5.1 Surround Audio *
* Logitech K200 Keyboard * Tt VersaII Mid-Tower Case * SeaSonic XP1000W PSU (100% Modular) *
Old 06-11-2010, 01:59 PM   #7
Sorry to hear that bud. Life and PC's can throw us some wild curves at times.
Old 06-11-2010, 09:01 PM   #8
Very nice Skully - those temps I get @ 3.3Ghz on air :eek:
Old 06-11-2010, 09:02 PM   #9
Man, that's a bummer - not cheap to replace either, sorry to hear P4.
Old 06-11-2010, 09:22 PM   #10
Thanks my friend, yeah water does do a better cooling job..
Old 06-13-2010, 09:33 PM   #11
Here's a template for R3E that may help.........
Target CPU Frequency 3800-4200MHz
Target DRAM Frequency 1603MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
Sync Mode [Disabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
CPU Ratio Setting [19.0 / 21.00]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
CPU Ratio Setting [19.0 / 21.0]
C1E Support [Disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualization Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Disabled]
Intel(R) C-STATE Tech [Disabled]
BCLK Frequency [200]
PCIE Frequency [100]
DRAM Frequency [1603]
UCLK Frequency [3208]
QPI Link Data Rate [7218MT/s]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 8 [8]
RAS# to CAS# Delay 8 [8]
RAS# PRE Time 8 [8]
RAS# ACT Time 24 [24]
RAS# to RAS# Delay 5 [Auto]
REF Cycle Time 72 [Auto]
WRITE Recovery Time 14 [Auto]
READ to PRE Time 8 [Auto]
FOUR ACT WIN Time 24 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 2N [Auto]
Round Trip Latency on CHA 56 [Auto]
Round Trip Latency on CHB 57 [Auto]
Round Trip Latency on CHC 58 [Auto]
WRITE To READ Delay(DD) 7 [Auto]
WRITE To READ Delay(DR) 7 [Auto]
WRITE To READ Delay(SR) 18 [Auto]
READ To WRITE Delay(DD) 9 [Auto]
READ To WRITE Delay(DR) 9 [Auto]
READ To WRITE Delay(SR) 9 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full Calibration]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage 1.356 [1.30000-1.35000]
CPU PLL Voltage 1.230 [Auto]
QPI/DRAM Core Voltage 1.230 [1.25000-1.30000]
DRAM Bus Voltage 1.654 [1.65625]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.111 [Auto]
IOH PCIE Voltage 1.508 [1.51050]
ICH Voltage 1.111 [1.11300]
ICH PCIE Voltage [1.51050]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
Old 06-29-2010, 01:39 PM   #12
Here's a snap shot of R3E with a i7 920 co stepping, oc'ed @ 445mhz.....
Old 06-29-2010, 03:24 PM   #13
Here's a snap shot of R3E with a i7 920 co stepping, oc'ed @ 4300mhz stable.
1 hr 0CCT no errors.......
Old 06-29-2010, 04:49 PM   #14
Hey DBoone, I just ordered a full cover R3E mobo water block.
Look at this link down to post #1245....nice and the only place
that has them is Block Ek.....***Asus Rampage III Extreme Owners Thread*** - Page 50 - XtremeSystems Forums
Old 06-29-2010, 05:11 PM   #15
DBoone
Just call me Dave
DBoone's Avatar
I'm anxious to hear how much difference it makes for you. Which version did you order?
