Old 06-03-2001, 06:23 AM   #1
hihihi
lm-sensors wrong cpu tempature ?
Anyone using lm_sensors to watch the cpu tempature ?
It say my cpu is 37 degree celcius..
But in the bios is gives a much higher value..
Does anyone know exactly how i need to configure lm-sensors to get the correct temprature values on a cusl2-c ??
Thank...
For the rest is all going well with red hat 7.1 and the cusl2-c here :-)
ASUS CUSL2-C BIOS 1006
CELERON 700
MATROX G450 16 MB AGP DUALHEAD
PHIIPS 105S21
QUANTUM ATLANTIS 22 GB
128 MB RAM.
LG 52X CD-ROM
CREATIVE SB LIVE!PLAYER 1024
RED HAT 7.1
msdos 6.22/win 3.11
Old 06-04-2001, 01:34 AM   #2
ShaMan_abx
No Expert - No Guru
You didn't say how much higher the temps are via the BIOS, so for the sake of expedience, I will assume we're talking 5-15 degrees or so difference.
I don't use the program you mentioned. However, don't worry about the BIOS temp readouts and the temp monitoring program within the OS reporting a difference, that is usually the norm, 37C is on average a reasonable temp.
Trust this helps, good luck.
Habentibus Symbolum Facilis Est Transitus.
Old 06-04-2001, 09:12 AM   #3
cryogen_abx
cryogen_abx's Avatar
hihihi
the temp reported in BIOS is the full oad temp..the temp u r getting in l_cpu is prolly at your desktop?? then it will always be less..
burn the cpu in for a while, those tempos should match the BIOS a little more...
hth
cryogen
umm nope
