Old 06-09-2001, 03:23 PM   #1
Unhappy suse linux network cards
hi all!!
Can anyone help?? I'm trying to install netgear network card driver into suse 7.1 from a floppy (oo-er!) seems I have to compile it or summit. I can't get into gcc though
Anyone help?? A step by step guide could be useful!!!!!
Cheers all
Old 06-09-2001, 07:27 PM   #2
No Expert - No Guru
Re: suse linux network cards
Hi, Col
I don't use SuSe, however, the UNIX/Linux related aspects would be all basically the same and I may be able to help you with that.
Unless, the drivers for your card are in RPM or similar format, then you will most likely need to compile the drivers yourself.
Before I can try to help you, it would help a lot to know, what exactly do you mean by your statement of:
"I can't get into gcc though"
Answer that and I may have a better idea what the problem is.
Habentibus Symbolum Facilis Est Transitus.
Old 06-10-2001, 11:57 AM   #3
cryogen_abx's Avatar
have you tried just running yast or yast2?
it's been a while for me, but i thought that was where you could reconfigure that stuph...
umm nope
