Old 07-24-2001, 11:59 PM   #1
Gorganzola
Gorganzola's Avatar
SuSE 7.1 & A7V133
Just ordered an ASUS A7V133 and an AMD Athlon 1.4GHz to go with it. It will be here in about a week. I was reading through the VIA 4-in-1 drivers and saw the patch for Redhat 6.1/6.2 so that it can use UDMA 100. I was wondering if anyone has successfully adjusted this to SuSE 7.1 or knows of a few places to look for the info.
TTFN.
A. One.
You can
in public.
Old 08-09-2001, 02:55 PM   #2
pointreyes
If you can take advantage of the SuSE installation help (through the first 60 days of purchase) check with them. SuSE can supposely install Red Hat rpm but 6.1/6.2 used Linux kernel much older than SuSE 7.1 (kernel 2.4.0). The 2.4 kernel series I thought supported UDMA100.
