Old 09-04-2008, 10:00 PM   #1
lalj
Is it my mobo? Ned clues.
After re-format and re-install OS, everything is great except I can't boot with my WD storage drive hooked up. It worked fine before. Its configured for storage via WD lifeguard tool. Bios shows it on hard drives list, but not on the boot list. It used to. I can plug it in after I boot and use it, but after shut down re-boot gets stuck in an endless cycle. Boot from F8 doesn't work either. I have to unplug it from the mobo and then it boots in record time. I use it to Ghost back-ups. Any Ideas please.
Michael.
____________________________________________
TT Tai Chi
ASUS A8N32-SLI DELUXE
AMD 64 x2 4800
XP Media Center 2005
Asus GeForce 7800 GTX 256MB
Theater 550 Pro
Sceptre X20G-NagaIII
Corsair TWINX2048-3500LLPRO
Seasonic S12-600w
Seagate Baracuda 500GB 7200.9
WD 320GB SATA
Norton Ghost 10
Drive it 'till it breaks
Old 09-04-2008, 11:25 PM   #2
rjs735
Virus? What I am not sick
rjs735's Avatar
Re: Is it my mobo? Ned clues.
Don't double post.
Optorite CDRW WD 40GB
All systems are networked
Old 02-02-2009, 09:04 AM   #3
Imanuel4u
Is your problem resolved ?
Imanuel4u
