Old 10-14-2006, 10:34 AM   #1
vanmol
Slow home page
HI---After installing and uninstalling a problematic Firefox, I began experiencing the trouble with opening my home page. I belive that some other sites are slower to open also. Hijackthis tells me that the URLSearchHook is missing---don't know if that is related or if I should fix that or not. Any suggestions would be appreciated.
Old 10-18-2006, 12:48 PM   #2
Vizual.Menace
UrlSearchHook is spyware, any type of spyware can cause a slow internet connection. Here is some info on urlsearchhook...
Installed files
File: pnqbfczz.exe
File: pnqbfczz.exe
Registry Entries
Registry Value Entry: {FD9BC004-8331-4457-B830-4759FF704C22}
Start Up Entry: pnqbfczz
Registry Value Entry: {6E6DD93E-1FC3-4F43-8AFB-1B7B90C9D3EB}
