Old 10-22-2006, 08:55 PM   #1
johnrr6
Lucky Amateur
johnrr6's Avatar
Ie7 Fast!!
Maybe it's just me......
But I find IE7 to be EXTREMELY fast!!
And once I got used to the tab features-----it has been a great move for me....
And this coming from a Microsoft basher.....
i7 3930 @ 4.6 GHz
Windows 7 Ultimate SP 1
Asus P9X79 Pro
Corsair H-100 Water Cooler
32 GB Corsair Devastator 1600 DDR
120 GB Crucial SATA III SSD
2TB WD Cavier Black SATA III
Sparkle Nvidia GTX-580
Samsung 22X SATA DVD Burner
Coolermaster Silent 850 Modular PSU
Coolermaster 690 II Advanced Case
Old 10-22-2006, 09:26 PM   #2
polonyc2
Legacy
polonyc2's Avatar
it is pretty fast, even with the phishing filter enabled...very spiffy
Intel i7 980X (Gulftown)
***** Noctua NH-U12P SE2
G.Skill Falcon I 256GB SSD
Lian Li PC-A70B (black)
***** Corsair HX850W
Lite-On IHAS424
***** NEC 2490WUXi LCD
Windows 10 Home 64-bit *****
Old 10-22-2006, 09:42 PM   #3
ATINUT
Just Plain Crazy!
ATINUT's Avatar
I like, as I don't have to have the third party Avant Browser on my system anymore. I've noticed that it is faster than IE6, way faster.
Intel D975XBX2 Intel Core 2 Duo E6600 8GB's of Mushkin HP2 6400 memory(DDR2 800) two Sapphire GDDR4 Radeon 3870 videocards HT Omega Claro(Cmedia 8788HD chip) 120GB&200GB&320GB Western Digital harddrives LG DVDROM & LG DVDBURNER HP Deskjet 920C Logitech X-540 speakers Viewsonic VG2030wm 20inch Widescreen LCD Windows Vista Ultimate 64bit with Service Pack 1
Who'se the fool that approved the design for this place. - The Dwarf, Sacred Underworld.
Old 10-22-2006, 10:17 PM   #4
Griff
Griff's Avatar
I installed it last night, seems pretty fast, will take a little getting used to. Will try it for a while on my main machine before installing on the other XP machines. I had to reconfigure my folding clients as they would not send the completed work units after the IE7 install.
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 10-23-2006, 08:07 AM   #5
Hmm... I've been having difficulty find my work group since installing IE7 - first I just thought it was a strange problem - but you comment makes me wonder.
Old 10-23-2006, 09:07 PM   #6
Griff
Griff's Avatar
I am not having any problems finding my Network groups. If a problem pops up I will let you know.
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 10-23-2006, 10:07 PM   #7
SlowJoeBlow
SlowJoeBlow's Avatar
I've been using it exclusivly as well but I must say I miss my "Make Link" and "Autocopy" extensions in FF
A8N-SLI Premium Bios 1009
AMD Opty 170 @ 2500 Vcore 1.360
2GB 2*1024 OCZ 4000 gold 3-3-3-5 1T
Asus NEN7800GTX
Antec NeroPower 480
19 " NEC MultiSync FE 950+
Old 10-23-2006, 10:38 PM   #8
Just a passing thought that network settings are being affected somehow. My wireless nic work flawlessly until I installed IE7 - this is really weirding me out.
Old 10-23-2006, 10:43 PM   #9
Griff
Griff's Avatar
I am using a wireless nic also on my main machine and two others with wired lan cards. No problems here.
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 10-24-2006, 05:58 AM   #10
Monkey Hanger
I'm WiFi on 2 of our laptops and both run IE7 without problems.
I think it must something else XJ.
Old 10-24-2006, 10:16 AM   #11
ATINUT
Just Plain Crazy!
ATINUT's Avatar
XJ, I'm starting to think possibly your wireless card is starting to die, or something with your Windows Configuration went to blazes.
I'm running TCPIP version 6 on my XP system, and don't have any problems with IE7.
Old 10-24-2006, 10:48 AM   #12
The wireless card is ok. Must be a coincedence. Bugger, I suppose I'll be beating my brains out finding the problem.
Old 10-24-2006, 12:31 PM   #13
Rick_EE
Sent from my PC
Rick_EE's Avatar
I can't get personalized favorites to work. I have tried enabling, disabling. A check of the registry shows that it is enabled. Maybe it takes a while, I am not sure.
Old 10-24-2006, 12:33 PM   #14
switch_abx
May be it's just me, but I think the new Firefox 2.0 is super fast. Can't compare it to IE7, because I just don't use it. IE7 was launched and within hours a major security vulnerability was discovered. A never ending story with M$.
Old 10-24-2006, 01:11 PM   #15
ATINUT
Just Plain Crazy!
ATINUT's Avatar
But did you know that the security vulnerability, actually doesn't exist in IE7, but exists only Outlook Express, so don't believe everything you read from Secunia.
I find IE7 way faster than IE6 for loading and rendering webpages, and I no longer have to have a tabbed browsing extension or run a 3rd party web browser anymore.
