Old 03-11-2007, 04:30 PM   #1
joseph
Member
joseph's Avatar
You guys are missing something...About the Hardware Requirments!
hi,
Here is what MICROSOFT SAID the RECOMENDED REQUIRMENTS to run WINDOWS VISTA HOME PREMIUM on all MAXIMUM apps
Remember its RECOMENDED, it's not MINIMUM, so that means 769MB will DO, like what i have.
HTML Code:
MICROSOFT SAID
Windows Vista Home Premium
Recommended system requirements
1 GHz 32-bit (x86) or 64-bit (x64) processor
1 GB of system memory
40 GB hard drive with at least 15 GB of available space
Support for DirectX 9 graphics with:
WDDM Driver
128 MB of graphics memory (minimum)
Pixel Shader 2.0 in hardware
32 bits per pixel
DVD-ROM drive
Audio Output
Internet access (fees may apply)
Additional requirements to use certain features
TV tuner card required for TV functionality (compatible remote control optional)
Windows Tablet and Touch Technology requires a Tablet PC or a touch screen
Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
Minimum supported requirements
Certain product features are not available with minimum supported requirements.
800 MHz processor and 512 MB of system memory
20 GB hard drive with at least 15 GB of available space
Support for Super VGA graphics
CD-ROM drive
See that MINIMUM, and RECOMENDED, 768MB RAM will do for AERO, *i am so smart:justkidding:*
Please read carefully, and slooooowwwwwlly next time,
Joseph
THE MINIMUM REQUIRMENTS FOR AERO
1GHZ processor (64-bit, or 32-bit)
768MB RAM DDR+
Geforce 4+ 128MB+ (256MB recomended)
32 bits per pixel
DVD-ROM Drive
But windows Vista itself, and AERO will run much faster with 1GB of RAM+, thats why Microsoft wants you to upgrade to 1GB if you don't have, they don't want your version of Windows Vista to be slow.
Edit: I did ReadyBoost, and added 512MB to my RAM with my flashdrive, and its much faster, AERO runs smoother and yes.
Hope this helps people,
Joseph
Old 03-11-2007, 05:22 PM   #2
ProCookie
Special Member - Vista Babble Promoter
ProCookie's Avatar
If theres one thing i have learnt with Microsoft its this, Don't go on there system requirements, they absolutely suck according to them Windows XP will run on a 233mhz 64Mb RAM computer......of course it would run crap on these specs.
Oh and on the subject of specs, in your sig you say "Direct X 10" well you actually need a DirectX 10 graphics card to take advantage of DirectX 10...oh and also Sapphire is spelt with two p's not one........Now whos smart
[COLOR="Red"][B][SIZE="2"]ALL THINGS WINDOWS 7 AND MORE!
[/B][/COLOR]
Old 03-11-2007, 05:46 PM   #3
joseph
Member
joseph's Avatar
Your verry smart, smarter then me!
Old 03-11-2007, 05:48 PM   #4
joseph
Member
joseph's Avatar
SO anthony, should I upgrade my RAM so I could get 1GB and fit their recomendation, or should I just stick with ReadyBoost, because my mom needs my Flashdrive now, and I don't want to unlug it, i seriously put tape around it and hid it behind some wires
Old 03-11-2007, 05:54 PM   #5
ProCookie
ProCookie's Avatar
It depends Joe, if your happy with the speed your computers running at leave it, If not upgrade. After reading your previous posts it seems to me that your computer runs surprisingly well with Vista but if you feel you need a little more kick out of your computer more RAM is definitely an option.
[/B][/COLOR]
Old 03-11-2007, 06:25 PM   #6
Znod
Znod's Avatar
I think that you would be even happier with more RAM--performance-wise.
[CENTER][sigpic][/sigpic]
[COLOR="DeepSkyBlue"][/COLOR]
[/CENTER]
Old 03-11-2007, 06:29 PM   #7
Mustangman76
Senior Member
Mustangman76's Avatar
Hi
You could also increse ur paging file..i did and i notice a big differance..good luck
Mustangman76[SIZE="2"][FONT="Comic Sans MS"][/FONT][/SIZE]
|Pentium M Centrino 1.60 GHZ|100GB HD|ATI Mobility Radeon X300|19 Inch LCD Widescreen|512 MB Ram|CDRW/DVD Rom|
Old 03-12-2007, 04:45 AM   #8
ProCookie
ProCookie's Avatar
hey thanks Mustang i used to do that with XP but i forgot about it in Vista, i have whacked mine up to 2500 and it does acutally have a great impact. Thanks!
[/B][/COLOR]
Old 03-12-2007, 09:04 AM   #9
joseph
Member
joseph's Avatar
mines page file is 100%, on vista i'ts getting slow as I increase the amount of usage, and install more files, i think ill replace the 256MB Stick of RAM with a 1gig Stick of RAM to get 1.5GB, do you guys agree?
Joseph
Old 03-12-2007, 09:11 AM   #10
Seansmit17
Seansmit17's Avatar
sounds good idea to me!
I cant use BB Codes in my sig!!!
Allow BB Code No
Allow HTML No
Old 03-12-2007, 09:26 AM   #11
joseph
Member
joseph's Avatar
Ok i'll be ofline, as I go to buy some more RAM, unfortunatly, i can't get a 1gig stick so im egtting 512 to replace my 256 to make 1GIG of ram
Old 03-12-2007, 11:19 AM   #12
Znod
Znod's Avatar
hi,
Are you able to use Aero Glass, and what is your Vista Experience Index?
[/CENTER]
Old 03-25-2007, 10:03 AM   #13
ewan_mclean
Senior Member
ewan_mclean's Avatar
I managed to get Windows Aero running on my motherboards chipset, I just wanted to see if it worked it was 128Mb, the base score of my PC went down to 2.3 and when my computer has the chipset running, I only have 896Mb of Ram
Old 03-25-2007, 11:49 AM   #14
Znod
Znod's Avatar
How did you do it. I'd like to see how my laptop runs with Aero. It satisfies all Vista requirements but WDDM--has the intel 915 chipset with integrated graphics.
[/CENTER]
Old 03-25-2007, 08:12 PM   #15
joseph
Member
joseph's Avatar
Index = 3.4 pfft, so sucky, i bet wheni upgrade my ram it'll be like 3.9 for my CPU, instead of my how aero performs on my computer, my Graphics card is 5.3, sheesh. Cow: Mooo! Human Being: That's what your Mother said! Joseph: What a couple of noobs!
