Old 03-27-2007, 09:21 PM   #1
haynesja
Junior Member
Used to Work
The cool 3D application switch windows in Aero used to work but now I get a 2D pane with a thumbnail of the page. Can't figure out what changed. Any ideas?
john
Old 03-27-2007, 09:30 PM   #2
Znod
Znod's Avatar
Welcome haynesja. Do you still have Aero transparency?
[CENTER][sigpic][/sigpic]
[COLOR="DeepSkyBlue"][/COLOR]
[/CENTER]
Old 03-28-2007, 01:35 AM   #3
crabby
Super Moderator
crabby's Avatar
Alt + Tab = 2D
Windows Key + Tab = 3D
Quick Bar shortcut = 3D
Do these not work then?
crabby
Old 03-28-2007, 08:24 AM   #4
haynesja
Junior Member
Seems like glass works but not vertical 3D pages. Just 2D flat plane with picture of current page
So no they do not work and I can't seem to find any configuration support.
john
Old 03-28-2007, 08:48 AM   #5
felix8406
felix8406's Avatar
When did you started having this issue? Did you install software/hardware? Maybe you can try System Restore to undo the culprit that's causing the issue.
Old 03-28-2007, 03:10 PM   #6
joseph
Member
joseph's Avatar
Did it work before?
Old 03-28-2007, 06:25 PM   #7
Seansmit17
Special Member - Vista Babble Promoter
Seansmit17's Avatar
Joseph... may i refer you to the title of this thread..
"Used to Work"
I cant use BB Codes in my sig!!!
Allow BB Code No
Allow HTML No
Old 03-28-2007, 07:51 PM   #8
haynesja
Junior Member
Thanks guys, Window's Key+Tab works. I just spaced how it was done. Thanks for the help. Everything back to normal.
john
Old 03-29-2007, 01:59 AM   #9
crabby
Super Moderator
crabby's Avatar
*ehem* Go me!
crabby
