Old 02-25-2005, 03:46 PM   #1
SupDawg
SupDawg's Avatar
**How to increase points per day with Folding @ Home**
Everyone, a somewhat new configuration has been released; we need to optimize our clients to increase our production. These large work units use quite a bit of RAM/ virtual memory and are large downloads 3- 5 MB, so caveat emptor. To use this configuration, simply stop the service or shutdown the client, and make a shortcut to the executable and place the flag –config on it. This will re ask you your settings that are already present in your “client.cfg” file.
Also, HT computers can run 2 instances. this includes Northwoods, Xeons, & Prescotts to increase points per day from 20 to 30%.
Folding @ Home does not care about memory bandwidth. All it cares about is pure clock speed.
If you need help setting it up, post here. Running these large work units will increase scores as much as 100% per day
I implore everyone to be using this setting, if possible!!
Here is a excerpt of potential production from a Gromac “large packet” WUs.
p1134_RIBO_FSpeptide_EXT (Gromacs) (NEW)
The one I have is worth 600 points and has 100 frames. Here are some frame times.
XP64 3500+ @ 2.5 GHz (250 HTT, memory at moderate timings. (NewCastle Core)
~27 minutes per frame
45h 38m per WU
13.47 points per hour
315.58 points per day
2208.696 points per week
p1134_RIBO_FSpeptide_HEL (Gromacs) (NEW)
XP 2100+ tbredB @ 1946 MHz (150 fsb, memory at moderate timings)
~44 minutes per frame
74h 20m per WU
8.07 points per hour
193.72 points per day
1356.096 points per week
Thats right, 1 Cpu can generate over 2000 points per week running only these proteins.. This is why this is important we use the switches. IF anyone has any questions comments/corrections please feel free to post em here!!
Thanks and Happy Folding!
The views expressed in this electronic dialogue are mine alone.
All physics are belong to me. " Kongo
Old 02-25-2005, 03:50 PM   #2
FB
yup and i thought you were going to up your clock speed a little more?
Old 02-25-2005, 03:50 PM   #3
John64
i am running that on my 1700+ and when my water is functional i will be folding using that again on my A64
Old 02-25-2005, 03:52 PM   #4
SupDawg
SupDawg's Avatar
Heh, I did on my Athlon rig... Running headless on that one ATM, so all overclocking must be done through windows at default voltages.... I wish I still have my 1700+..... Man that thing was a clocker.. Default 1.4 Ghz... I had that thing running @ 2346 mhz for over a year... Why did I sell it...
So the reason why I posted this is because I never knew it was such a huge increase... Man, could have done this a long time ago, ah.. but I didn't know...
Also, I might add that for extremely slow computers, this may not be the best choice... It would be nice to see how long a 600 pointer would take on a >1Ghz machine, and if it would garner gains in PPW over regular work units.
Old 02-25-2005, 04:33 PM   #5
Underwater Mike
Underwater Mike's Avatar
Isn't the same thing as adding "bigpackets=yes" to the client.cfg file? Or is that something different?
Old 02-25-2005, 04:59 PM   #6
MANOWAR
Call To Arms
MANOWAR's Avatar
SupDawg,
You are way too cool, thanks for this info!!
Just 2 questions:
1) I notice you are answering "Yes" to "Use IE Settings"
Is that correct? I thought I read in another thread to answer NO to this one. Should I reconfigure and answer yes instead?
I have been receiving new work units and sending results without any problems.
2) If I'm reading the quote below correctly what you're saying is: If you have a P4 machine with Hyper-Threading enabled you can run 4 consoles per computer?! I have only been running 2 with hyperthreading. 1 if no hyperthreading.
Do I have this right? 4 consoles on one computer?
Thanks again
Originally Posted by SupDawg
Also, all new Northwood "C" owners with HT can use two instances per logical cpu to increase points per day from 20 to 30%.
Old 02-25-2005, 06:42 PM   #7
Griff
Griff's Avatar
What about Prescott cpu"s? does it work for them also.
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 02-25-2005, 06:47 PM   #8
FB
any HT enabled processor you can run 2 total consoles on, no more because you only have 1 logical cpu. HT just tricks the apps into thinking you have 2 processors (for the most part, that is how i understand it)
Old 02-25-2005, 07:17 PM   #9
zsaz1029
zsaz1029's Avatar
SupDawg, is there a reason that you're not using the latest version of the console?
Spaz
"A scar is never the same as good flesh, but it stops the bleeding." -- FitzChivalry Farseer (Assassin's Quest by Robin Hobb)
"Only my pain is more silent than my anger." -- Amber (The Liveship Traders by Robin Hobb)
Old 02-25-2005, 07:33 PM   #10
Griff
Griff's Avatar
SupDawg
Thanks again
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 02-25-2005, 07:34 PM   #11
FB
SupDawg
Thanks again
griff, i already answered your question.
1 processor w/HT(northwood or Prescott) = 2 consoles, no more.
2 processors w/HT (Xeons)= 4 consoles.
Old 02-25-2005, 08:35 PM   #12
SupDawg
SupDawg's Avatar
Sorry about the confusion, HT computers can only run 2 instances. this includes Northwoods, Xeons, & Prescotts.
Old 02-25-2005, 08:36 PM   #13
SupDawg
SupDawg's Avatar
no particular reason(lazy). Should I?
Old 02-25-2005, 09:11 PM   #14
Griff
Griff's Avatar
Thanks for the clarification. It sounded like from your post you could run 4 instances but I did not think so.
LG BlueRay Burner
Built in Card Read
Win10 Pro
Old 02-25-2005, 09:24 PM   #15
zsaz1029
zsaz1029's Avatar
From http://folding.stanford.edu/winchanges.txt
RECENT CHANGES (Client):
5.02:
- Error checking on queue, related to big packet option.
Can't say I know exactly what this change means, but it has to do with the big packet option you're refering to.
Spaz
