#1 |
Computer Maniac
How to format a USB Flash Drive as MS-DOS Start Up Disk?
Hello all you experts out there. I know someone can help me. I've just bought myself a USB Flash Drive (actually it's free with a purchase of CDR disks). I want to use it as a MS DOS start up disk, so I can boot from it for PC repair purpose. The software that comes with it doesn't support that option (under Format option) under XP, only under Windows 98. So, how do I go about formatting it with MS-DOS (like option when you format a floppy disk under XP and it has Create an MS-DOS startup disk). Can anyone help? Thanks...
MSI Eclipse Plus, Intel Xeon W3550, 6GB (3x2GB) Corsair DDR3-1600, BFG 9600GT 512MB DDR3 EVGA E770 6GB (3x2GB) Mushkin Red 998707 with Intel i7 950 and EVGA GTX285 SC 1GB DDR3 Asus M4A89GTD-Pro/USB3 with AMD Athlon X2 555 BE, 4GB (2x2GB) Crucial Rendition Asus A8N32-SLI Deluxe, A64 4000+, EVGA 7600GT OC Gigabyte P4M900-M4 Rev. 6.1, P4 3Ghz Prescott, 2GB OCZ Gold (2x1GB), EVGA 8500GT 1GB DDR2 |
| (Offline) |
#2 |
This worked for me, and it works on other drives as well. Search HP.com for SP27213.exe.
| (Offline) |
#3 | |
Computer Maniac
| (Offline) |
#4 |
Re: How to format a USB Flash Drive as MS-DOS Start Up Disk?
hello
how you that please cos i can not do that. on the dos system file locate at,first i browse to folder system32 second i browse to system and third i browse to C:, but it all appear there are no valid DOS system file locate at the specifies location could you help me please! thanks Heng |
| (Offline) |
#5 |
Thanks I was just about to look for that. I have the util that turns the entire flash drive in a win98 boot drive, but I need something that would only make it floppy sized (to load a bios).
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Asus P6T Deluxe V2, Ci7 920 @ 4GHz, 512GB Crucial M4, MSI GTX 680 Power Edition @ 1200MHz 12GB G.Skill Ripjaws 1600 MHz, Corair 850HX, Corsair H100 LC, Corsair 800D case. Windows 7 Ultimate 64b |
| (Offline) |
#6 |
Full instructions
WeetHet - Boot from USB Flash drive
Mobo: Asus P5B Deluxe CPU: Core 2 Duo E6750 Memory: 4GB DDR800 Video: GeForce 260GTX 896MB OS: Windows 7 Pro 64bit RTM (and XP Pro) Sound: Auzentech Prelude X-Fi |
| (Offline) |
#7 | |
HP USB Disk Storage Format Tool V2.1.8 is working great! |
| (Offline) |
| Thread Tools | |
| Display Modes | |
