Old 04-03-2006, 12:05 PM   #1
DCR
Working For The Weekend
Starting a Forum?
I was wondering what it really takes to make a forum like this?
I wanted to start a forum related to cars a couple of years ago, but never did it. Now, I have been looking around at domain registration, web hosting and PHP forum stuff.
I looked at Godaddy for hosting and domain reg, but I want to be sure I know what I am getting into first.
Does anyone have any advice on domain reg sites (cheaper the better) and hosting?
How about advice on the forum portion?
Easy is best, of course.
*the above post possibly contains severe sarcasm, humor or stupidity....rarely will it contain helpful information or material.
A64 3500+
Koolance Exos CPU and GPU Cooling
MSI Neo Platinum
512 x 2 OCZ Performance Series RAM
ATI X800XT PE WC
Antec Lanboy w/OCZ 520 W PSU
200g and 120g Seagate 7200 HD's
Old 04-03-2006, 12:25 PM   #2
John64
All you need to do is get a server, forum software and a domain. GoDaddy is what they use for anyother forum i am on and its great. I think they take care of everything from Domains to the actual hosting. THey have their own Virtual Machine
Old 04-03-2006, 12:33 PM   #3
DCR
Alrighty...say I use Godaddy for the name and hosting...
I would then have to design the forum and upload the template?
I will have to look around for a resource on how to make the forum part.
A64 3500+
MSI Neo Platinum
ATI X800XT PE WC
Old 04-03-2006, 12:59 PM   #4
John64
you can get allready made forum systems from vBulletin (here), phpBB, Invision Power Bulletin, YaBBForum. They are very goog, though i would recomend phpBB personally.
Old 04-03-2006, 03:23 PM   #5
DCR
Cool, thanks!
I am going to dig around and see what options are there for the forums you have listed.
A64 3500+
MSI Neo Platinum
ATI X800XT PE WC
Old 04-03-2006, 03:29 PM   #6
Bofinn
I'm gettin' dizzy!
Bofinn's Avatar
here is an old thread with the same question:
http://www.abxzone.com/forums/showthread.php?t=79060
---------- JimBo -----------
When in doubt, smack it!
Old 04-03-2006, 03:39 PM   #7
DCR
Thanks, Bofinn!
I did see that thread earlier when I searched, and I wanted to ask this now to make sure nothing had changed.
Maybe I should have just bumped that one?
A64 3500+
MSI Neo Platinum
ATI X800XT PE WC
Old 04-03-2006, 03:40 PM   #8
Bofinn
I'm gettin' dizzy!
Bofinn's Avatar
new works just as good! good luck.
Old 04-03-2006, 06:09 PM   #9
Protoplasm72
Mmmm..... Folding@Home
Protoplasm72's Avatar
Godaddy has some applications that you can load with just a few clicks. They have a couple different blog apps, etc... The only forum software I saw was http://www.simplemachines.org/ . It would probably be the easiest forum to setup if you went with godaddy. I haven't tried installing any of their apps yet though.
Good luck
proto
"Friends, Family, Religion... These are the three demons you must slay in order to succeed in business" C.M. Burns
Old 04-03-2006, 09:50 PM   #10
Wired_abx
Wired_abx's Avatar
Read this, and read carefully!
www.theadminzone.com
Admin at
(AKA
) - R.I.P.
Moderator at
Founder/Creator/Admin of
(Coming Soon)
Old 04-03-2006, 10:48 PM   #11
fords8
fords8's Avatar
I been wanting to start a hot rod website/forum for sometime now. Are you planning on doing a hot rod site or just any type of car site?
Old 04-04-2006, 12:40 AM   #12
DCR
I think it will be import car based, but I am not 100% sure yet.
...and nice link! I will read around there for sure.
A64 3500+
MSI Neo Platinum
ATI X800XT PE WC
Old 04-04-2006, 03:12 AM   #13
FightingChance
Yes, I am better than you
FightingChance's Avatar
I get my hosting from Telnap (http://www.telnap.com/). Their Fantastico control panel has a free phpBB drop-in that I think is pretty nice.
I'm not so sure about getting the hosting at the same place you get your registration. The convenience usually equals increased fees.
Old 04-04-2006, 08:22 AM   #14
DCR
I had this feeling, really, because during the signup process with Godaddy for a domain name, I had all different kinds of offers popping up. I stuck with the basic domain and now I am checking hosting. Thanks for the link, too.
A64 3500+
MSI Neo Platinum
ATI X800XT PE WC
Old 04-04-2006, 06:04 PM   #15
Wired_abx
Wired_abx's Avatar
If you're serious about the forum, I'd spend some cash to buy forum software (e.g. vBulletin that ABX and HoH runs off of, or IPB, that HTPCNews runs off of)
Admin at
(AKA
) - R.I.P.
Moderator at
(Coming Soon)
