Old 06-12-2006, 01:53 AM   #1
switch_abx
New Forum: Virtualization Technology
Considering the fact that Intel now integrates its VT technology in its chipsets/processors and AMD also is jumping on this bandwaggon, I thought it would be interesting to include a new Forum on this subject at abxzone.com.
My guess is that Virtualization Technology is going to play a big, a very big, role for all of us. I am particularly interested in Intel's VT technology and Xen. Imagine, running FreeBSD, several Linux distributions, XP, Vista, Windows Test system, a Linux Test system, one for Games, one for Chatting, one for Business, whatever you want to throw at it, on one box. Yes, on one PC, Notebook or Server. And if one server crashesm it won't crash the other virtual servers.
Yesterday I discussed with a friend of mine to start a project, using Xen 3. The plan is to retire my four (hardware) Servers, replace them and add antother two to arrive at 6 Virtual Servers residing on one hardware serversystem. What an opportunity to save costs and consolidate several systems on one hardware platform.
For those who are not yet familiar with Virtualization Technology, here are some links, which cover this subject:
http://en.wikipedia.org/wiki/Virtualization_Technology
http://www.intel.com/technology/computing/vptech/
http://www.intel.com/cd/ids/develope...9939-c1-130362
http://en.wikipedia.org/wiki/Xen
http://www.cl.cam.ac.uk/Research/SRG/netos/xen/
http://www.xensource.com/
abxzone peers, what do you think of my proposal? Finally something new and a breakthrough (for us) to the current, boring and stalemate information technology.
Old 06-12-2006, 04:04 PM   #2
sorrow
010011100100100101001110
sorrow's Avatar
While i do use vmware, i don't know if i would need/use a seperate forum for it. I think switch is on track with this, but maybe just a little premature. I think in a couple years we will all use vm's to surf due to the high volume of atrocious attacks via onlin surfing.
my .2
I'll need to update this when I get a moment.
Old 06-12-2006, 04:36 PM   #3
It should be a vendor-agnostic forum if anything. AMD has its Pacifica which is similar to Vanderpool Technology.
The problem may then be that vendor-specific topics are discussed in this forum, but I guess that would be better than splitting up the whole virtualization topic over two separate forums. A lesser of two evils, if you will.
I think it would be a nice addition, albeit, as sorrow pointed out, quite early in the use of hardware-assisted virtualization. VMWare and such have been in heavy use in corporate environments for quite some time.
I'm for it, I guess was the gist of the above.
Old 06-13-2006, 03:57 AM   #4
Tinker
How did they do that???
Tinker's Avatar
switch has a very good idea. I just spent about an hour looking over some information on this topic and I have questions. I have many times answered my questions by reading the forms here and never had to post anything. This looks like a growing area and we should provide as much information via a form as we can.
Old 06-14-2006, 09:36 PM   #5
Ozzie
CRS Designee
Ozzie's Avatar
I think I can see where the thinking is here...ABX has the choice of either leading or following. While we may be ahead of the curve, this could also provide something other sites don't and it may help stimulate the forums.
Since this is available across platforms, it would seem to me one single forum possibly called "Virtualization Technology (VM, VMware, Xen, Intel VT, AMD Pacifica, etc)", (or some variation) as switch suggested would be the way to go.
Also a consideration is the fact that this is mostly software based at this point (as noted by kONGO), so it would seem to fit better as a sub forum in software along with the OS's. As things change (you know they will), we will have to adapt.
So...it sounds like I'm onboard too, ABX needs to be forward thinking...and I appreciate the suggestion to provide more opportunity for discussion.
Have you supported your forum today?
Change is the only constant in life
Old 06-15-2006, 03:23 AM   #6
The thing is, Virtualization is a software solution. VT and Pacifica are just core-level functionalities to assist the software stack to make it easier to virtualize the hardware (e.g. instead of managing different memory spaces entirely in software, the hardware has functionality to ease that). So I think that regardless, the forum should be a Software category forum.
Anyway, virtualization won't be entirely cool until the whole hardware system can be virtualized. PCIe has virtualization features in the next spec, for example.
Old 06-15-2006, 07:02 AM   #7
switch_abx
Ozzie, I cannot more agree on what you stated.
Originally Posted by Ozzie
......ABX has the choice of either leading or following. While we may be ahead of the curve, this could also provide something other sites don't and it may help stimulate the forums.....
......So it sounds like I'm onboard too, ABX needs to be forward thinking and I appreciate the suggestion to provide more opportunity for discussion.
Old 06-15-2006, 07:09 AM   #8
switch_abx
With Xen you can create Virtual Adapters (Network Inteface Cards) and even create MAC addresses for those Virtual Adapters (either have it done automatically or you can do it manually). Imagine you have one PCIe based NIC, but you can create n Virtual Adapters on your box, all IP traffic running through that one NIC. I get so excited when I think of all the opportunities which Virtualization Technology already can offer today. I hope you all get as excited as I am.
Originally Posted by kONGO
...PCIe has virtualization features in the next spec, for example.
Old 06-15-2006, 08:11 AM   #9
Yes, but that's a pure software solution whereas the hardware doesn't know what virtualization is.
The future specs for PCIe include the concept of virtualization. Basically you would then have the ability to seamlessly have multiple OS images access the same hardware at the same time (queued, of course, but it appears to be simultaneous). Now only one image can access the hardware at any point in time, as far as I know.
This is for PCIe 2.0 from what I've read.
Old 06-15-2006, 08:39 AM   #10
switch_abx
kONGO, thanks for your feedback. Yes, I realize that this is a software solution only. However from reading the documentation of Xen I am under the impression, that it is indeed possible for all Virtual Servers with their Virtual Adapters, to have all IP traffic flow through that one (hardware) NIC. I may be wrong, though.
Old 06-15-2006, 05:11 PM   #11
switch_abx
May be this explains why Xen is able to do this, as opposed to other Virtualization Software?:
quote:
".....a built-in hypervisor rather than a software layer that manages resources between the host and guest operating systems. "If a hypervisor is embedded in the operating system, it will tend to be a more natural fit," said Gordon Haff, principal IT advisor for Illuminata Inc., an IT consultancy based in Nashua, N.H. Licensing considerations are another reason that users may choose an embedded hypervisor over one that is an add-on, Haff said."
unquote
Here is link to the complete article:
http://searchservervirtualization.te...191607,00.html
Old 03-27-2008, 06:28 AM   #12
jaketerminate
Maximum Post
jaketerminate's Avatar
Re: New Forum: Virtualization Technology
Very helpful, good job!
"Mozart" Rig #1
Case: Thermaltake Mozart TX
Mobo: Asus P5N-E
CPU: Intel Core 2 Quad Q6600 2.4ghz
Memory: 4GB (2x 2GB) G.Skill DDR2
Hard Drive: 320 GB Western Digital 7200 RPM
Video Card: EVGA Nvidia 9800GX2 1GB (512MB per GPU)
Power Supply: 600W OCZ StealthXStream
OS: Windows XP Homee Edition and Ubuntu Linux x64
Monitor: 22" Westinghouse LCD and 2 Dell CRTs
HP G60t
CPU: Intel Pentium 2.0ghz
Memory: 4GB
Hard Drive: 250GB 5400RPM
GPU: Intel Graphics Media Accelerator 4500M
OS: Windows 7 Ultimate Build 7000 Beta + Ubuntu Linux
HP Pavillion tx 2000z Tablet
CPU: AMD Turion x2 2.1Ghz
Memory: 3GB
GPU: ATI Radeon 3200 64mb
1TB Seagate External Backup Drive
Old 03-27-2008, 07:29 AM   #13
TQ
You gonna throw that?
TQ's Avatar
Aw, man. I thought the headline said "newd forum" and it was one of those cool, deliberate mashups of the English language so popular with the kids these days.
Instead what do I get? More tech talk!
Create in me a pure heart, O God, and renew a steadfast spirit within me - Psalm 51:10
My goal in life is to be as good of a person as my dogs already think I am...
Daywalker Studio:
Software: Adobe Audition 3.0/Pro Tools LE 7.4/Acid Pro 6.0/Multiple VST, DirectX and RTAS plugins/Kontakt 3 Sampler/Windows XP Professional
PC Hardware: D975XBX2-504/E6600/4x2GB Mushkin XP2-6400/eVGA 800GTX/HP f1905 19" flat panel/Echo Audio Gina24 Sound Card/2 Maxtor 6B300SO's/1 Maxtor STM500AS/1 Western Digital WD2500JD/PleXwriter Premium/Plextor 716A/Samsung LightScribe DVD burner/Logitech Revolution MX/Antec P-180b/PPC&C Silencer 610/Zalman CNPS9500 HSF
Recording Hardware: Mbox 2 Factory Pro/Mackie SR24.4VLZ Pro Console/M-Audio Axiom 25 MIDI Controller/Audio-Technica 4033a microphone/Symetrix 528E/PreSonus Eureka/Mackie MR8 active monitors
Game Machine: Gigabyte GA-X48-DQ6/E8400/4x2GB Mushkin XP2-8500/BFG GTX280/HP f2105 21" flat panel/Creative Labs X-Fi Elite Pro/Maxtor 6H500F0/Maxtor STM3320/Western Digital WD4000KD/Plextor 760A/Toshiba DVD-ROM/Zalman CNPS9700/Antec P-180/PPC&C Silencer 610/Ideazon Merc Stealth keyboard/Vista Business64 SP1
