Old 07-15-2006, 01:51 PM   #1
trionalaw
CPU temperature monitor free download
I cannot determine the CPU temperatures of my new rig. With my old one I had an ASUS motherboard that had the probe feature you could put in your toolbar.
I was thinking of overclocking a little bit using the clock generator program. Does anyone know if there is an onboard temperature program with a Dell? If not does anyone know of a CPU temperature download (of course for free).
I did my searches on the forum but found nothing. Of course, no one said I was Stanley Livingston.
As always, I appreciate very much your help. Thank you.
Jim
Dell Dimension XPS 600
Intel Pentium D950 one
Chipset nVidia nForce4 SLI Intel
2 GB 667 MHz OCZDDR2 PC5400 Value Pro
NVIDIA duel GeForce7900 GS
250 GB SATA II 7200RPM hard drive
X-FI SoundBlaster PCI
Windows XP
Dragon Naturally Speaking Version 8.10SP1
KnowBrainer Version 2005(rev. 2a)
Old 07-15-2006, 03:04 PM   #2
3 of 7
You can run.....
3 of 7's Avatar
You could give Motherboard Monitor a try
http://mbm.livewiredev.com/
Old 07-15-2006, 04:26 PM   #3
wonderwrench
wonderwrench's Avatar
Speedfan should work. You may have to enable Dell support.
http://www.almico.com/sfdownload.php
Old 07-16-2006, 02:23 PM   #4
trionalaw
Thank you both for your responses. Wonderwrench, I could not download the site you referred me to. What did you mean I may have to enable Dell support?
Much appreciated.
Jim
Windows XP
Old 07-17-2006, 03:30 AM   #5
wonderwrench
http://www.almico.com/speedfan428.exe
There is a adjustment in speedfan to enable support for dell laptops so you do not need it, I was mistaken.
