#1 |
Just like Windows XP, Vista has a feature called zip folders which shows each zip & cab file as a folder in explorer. Now some people may like this feature and some may not. I personally hate it, so the first thing I tried to do was disable zip/cab folders in Vista like they way you do it in XP, and it doesn't work.
For Vista, you'll have to edit the registry and remove these keys: HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31} HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262} If you aren't comfortable manually editing the registry. Then just copy and past this into notepad and save as DisableZip.reg and run it. Will take effect after you reboot. DisableZip.reg Code:
Windows Registry Editor Version 5.00
[-HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}]
[-HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}]
And if you ever wanted to undo it: EnableZip.reg Code:
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}]
@="CompressedFolder"
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}\DefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,\
00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,7a,00,69,00,\
70,00,66,00,6c,00,64,00,72,00,2e,00,64,00,6c,00,6c,00,00,00
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}\Implemented Categories]
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}\Implemented Categories\{00021490-0000-0000-C000-000000000046}]
@=hex(0):
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}\InProcServer32]
"ThreadingModel"="Apartment"
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}\ProgID]
[HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}\ShellFolder]
"Attributes"=dword:200001a0
"UseDropHandler"=""
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}]
@="Cabinet File"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\CLSID]
@="{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\DefaultIcon]
@="cabview.dll,0"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Implemented Categories]
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Implemented Categories\{00021490-0000-0000-C000-000000000046}]
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\InProcServer32]
@="cabview.dll"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell]
@="none"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\find]
"SuppressionPolicy"=dword:00000080
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\find\command]
00,5c,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,2e,00,65,00,78,00,\
65,00,00,00
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\find\ddeexec]
@="[FindFolder(\"%l\", %I)]"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\find\ddeexec\application]
@="Folders"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\find\ddeexec\topic]
@="AppProperties"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\Open]
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\Shell\Open\Command]
65,00,20,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,00,25,00,49,00,2c,\
00,25,00,4c,00,00,00
"DelegateExecute"="{11dbb47c-a525-400b-9e80-a54615a090c0}"
[HKEY_CLASSES_ROOT\CLSID\{0CD7A5C0-9F37-11CE-AE65-08002B2E1262}\ShellFolder]
"Attributes"=dword:680001a0
| (Offline) |
#2 |
Zipped folders in Vista
I installed WinRAR and accidently selected .zip to be associated with the program and now can't change it back. I try deselecting the option, uninstalling the program, and no joy. I'm a simple user and much prefer the inbuilt .zip handling but your registry patch doesn't seem to work for this situation. Can I manually edit the file associate and the command it uses to restore this functionality that so many hate? |
| (Offline) |
#3 |
Is this XP or Vista?
| (Offline) |
#4 |
Sorry, it's Vista Home Premium.
| (Offline) |
#5 |
Not too sure, since I already changed mine to be associated with 7-zip.
Try this, it's from XP, but may work: Windows XP File Assocation Fixes |
| (Offline) |
#6 |
Thanks! As good as new!
All functionality is restored, although it opens zip file folders in a new explorer window now, but I can't remember if that's normal or not. Thanks again, |
| (Offline) |
#7 |
Thank you very much!
I had the problem that Vista Explorer kept showing the magnifying glass when opening some folders instead of displaying the subfolders in the folder pane. Disabling zip folders fixed this. |
| (Offline) |
| Thread Tools | |
| Display Modes | |
