#1 |
Gelsinger demos USB 3.0, PICe 3.0 and other new toys
PAT GELSINGER GAVE the afternoon keynote at IDF today, and it started off with some rather tame enterprise parts, then moved on to the fun stuff. First up was virtualisation, and a show and tell of the virtualisation vendors.
The one interesting one was presented by John Fowler of Sun with its upcoming, unannounced VM on its unannounced Tigerton/Caneland box. The most interesting bit is that, because it is running on Solaris,and you run Windows under that, the IO and storage are Solaris based and simply exposed. If you run Windows under Solaris, you get a real fault-tolerant file system on a toy OS. The one time Itanium was mentioned was in a new Hitachi Virtage blade. This blade is running Montvale, aka Montecito v.07. Other than that, the red-headed step-chip was absent from just about everything. Gelsinger demos USB 3.0, PICe 3.0 and other new toys |
| (Offline) |
#2 |
Re: Gelsinger demos USB 3.0, PICe 3.0 and other new toys
USB3.0 is probably going to be the biggest one of the bunch. They are aiming for 10-times the bandwidth, which would put it at about 5Gbps. For this you need optical, and USB 3.0 cables have an optical link in the current form. Backwards compatible, loads of bandwidth, optical and hopefully available in 1H/08.
Now that does sound nice. |
| (Offline) |
| Thread Tools | |
| Display Modes | |
