Old 10-03-2007, 09:57 AM   #1
WHB
WHB's Avatar
Microsoft Office 2007 Groove Monitor Removal
Hello, this thread is to address the program in Microsoft Office 2007 Enterprise Edition named Groove Monitor. The subject i will talk about is removing Groove from your PC. There are a lot of inquiries on the Web as to how can it be disabled or removing the bundled program. when installing Office 2007 I was aware that Groove had been installed but as time went on I began to realize that it showed up in System Configuration Utilities startup tab, which we know you can stop the program from running at startup, but i began looking for solutions as to how I could totally disable Groove, so I Googled for the solution but didn't come across a good solution as to how it could be done.
This is when the solution came to me and this is how to do it, many are looking for the solution when it is right under there nose, some are looking for a Groove Monitor entry in Add and Remove which there is no entry, it is as simple as going to (Add and Remove>Microsoft Office Enterprise 2007>Change (not Remove)>Check the Add or Remove Features button>Go to the Microsoft Office Groove entry then expand then check Not Available, there will be a red X placed there, then click continue, then let the removal process do it's thing and you will no longer have Groove on your PC.
P4C800-E Deluxe, Bios 1023
Intel 3.2C Ghz 800MHz FSB HTT
OCZ Dual Channel Gold 1GB DDR PC-3200
Asus ATI Radeon 9600XT, 128 DDR
Thermalright SLK_947 Copper, 92 mm Vantec "Tornado", 2 120mm supplied case fans
Antec 550W "True550"
Thermaltake Shark Case, Silver
2 Seagate 120GB 7200RPM SATA Drives Raid0
Shuttle CR40 16X DVD Combo Drive
Logitech G5 Optical Mouse, and Media Elite Keyboard
Windows XP PRO SP2
Detroit, Michigan
Interests: A Man of Many Talents
Old 10-03-2007, 10:01 AM   #2
SRTDodge05
SRTDodge05's Avatar
Re: Microsoft Office 2007 Groove Monitor Removal
Pretty standard for any package software to remove a part you dont want.
Old 10-03-2007, 10:25 AM   #3
WHB
WHB's Avatar
Yes it is, but believe it or not there are lots of people who are inquiring as to how to do it, because some are looking for the Groove entry in Add and Remove.
So there's nothing wrong with giving a helping post.
Windows XP PRO SP2
Detroit, Michigan
Old 10-03-2007, 10:28 AM   #4
SRTDodge05
SRTDodge05's Avatar
Sharing info like that for the first timers to learn will help them out.
Old 10-24-2009, 06:01 PM   #5
beckhousebooks
WHB - Thank you so much. You have truly saved the day. I installed Office Enterprise 2007 on my new hard drive recently. Today I installed My Sam's Club Digital Photo Center from the photo disk and attempted to upload my photos from my disk. I kept getting an error message similar to this one:
Couldn't find libary MSVCR80.dll (required by C:\PROGRA~1\MICROS~3\Office12\GrooveUtil.DLL) Please ensure that it is installed.
I spent all afternoon reading forums about msvcr80.dll -- and my head was spinning. I finally deduced that Microsoft Groove was the problem. Fortunately, I found your post and your very simple step-by-step instructions. After uninstalling Microsoft Groove, I was able to reinstall My Sam's Club Digital Photo Center and load my pictures on to my computer.
Thank you ever so much for your help.
Kindest regards,
Nan
Old 10-24-2009, 07:52 PM   #6
Nan, thank you for your extremely gracious expression of appreciation to WHB, and
to ABXZone.
ABXZone Moderator
Old 11-05-2009, 01:28 PM   #7
pajamas
Hello this is my first post
thank you for this quick guide, needed to uninstall. ever since i installed office 2007 my computer keeps crashing when i try to upload things. turned off one other possible cause of the problem and MS groove, hoping that will stop my crashes. thanks for recipe.
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
© 2006 - 2009 ABXZone Forums | About ABX Zone Forums | Advertising Opportunities | Legal | A member of the Crowdgather Forum Community
