Old 10-04-2007, 12:08 PM   #1
swannema
swannema's Avatar
OpenSUSE 10.3 released
Software.openSUSE.org
Here is a fast server:
ftp://ftp.tu-chemnitz.de/pub/linux/o.../10.3/iso/dvd/
Old 10-04-2007, 12:12 PM   #2
FearFactory
The FC.Porto dragon!
FearFactory's Avatar
Re: OpenSUSE 10.3 released
Thanks, downloading now
AMD Phenom II X2 555BE 3.2Ghz AM3 (OC x4 3.7Ghz),CoolerMaster Hyper 212 Plus, Asus M5A99X Evo , 2x 4GB DDR3 1600Mhz Corsair Vengeance, VGA PowerColor HD6950 2GB DDR5, Asus DVDRW, Seagate 2TB SATA, Seagate 500 SATA, PSU Nox Hummer M 650W, Asus ML239 23' IPS
Old 10-04-2007, 12:22 PM   #3
yamawho
Linux user
yamawho's Avatar
Thanks for the link old buddy
No time to play but would like to hear feedback
Old 10-04-2007, 12:29 PM   #4
FearFactory
hmmm no download resume support on this server need to find another place to download it.
Old 10-04-2007, 12:35 PM   #5
Is it possible to dist upgrade without the whole thing going kaboom?
It's either 10.3 or Ubuntu 7.10. I'm leaning towards the latter, but if I could test-drive 10.3 without much fuss that'd be a plus.
Old 10-04-2007, 01:14 PM   #6
swannema
swannema's Avatar
You can always use a torrent:
ftp://ftp.tu-chemnitz.de/pub/linux/o....3/iso/torrent
Old 10-04-2007, 01:17 PM   #7
swannema
swannema's Avatar
An update from 10.2 shouldn't be too bad, unless you have a lot of third party software installed.
I plan to do an update as well, after I have saved my home partition and ~/etc.
But first I go on vacation, the Tuscany and Paris are more important for now.
Old 10-04-2007, 01:26 PM   #8
wallijonn
PHX
wallijonn's Avatar
Isn't it a beta, by virtue of the fact that it is an odd numbered iteration? If so, then I'll wait until 10.4, the stable version, because when I installed 10.1 it never did any updates.
D875PBZLK, MAC G4-933
Old 10-04-2007, 01:56 PM   #9
swannema
swannema's Avatar
No, it is not a beta. the next version will be 11.0, to be released in 6-8 months.
Old 10-04-2007, 02:15 PM   #10
FearFactory
Originally Posted by swannema View Post
I changed to another download manager, it works fine now. I'm on an 512kb's ADSL line, that's why i need to resume.
Old 10-05-2007, 10:33 AM   #11
FearFactory
Still downloading it... anyone tried already?
Old 10-05-2007, 10:54 AM   #12
Sweet - have fun swannema!!
Old 10-05-2007, 02:01 PM   #13
wallijonn
PHX
wallijonn's Avatar
I guess I chose the wrong word. What I meant to say was "Stable Version". Alphas and Betas are not stable versions. Is 10.3 stable and will it update? Or will it be stable and no updates?
I would think that 11.0 would only apply to KDE4. Since I am a GNOME man I could not care less. I no longer live on the bleeding edge. Just give me a stable release and I am happy.
Old 10-06-2007, 12:50 PM   #14
Cogar
Level 16, lawful good
Cogar's Avatar
10.1 was just plain a bad release, which was a result of some developers having too much say in the release process and adding alpha-level software into the build, while pretending the work was release candidate quality. Novell was never able to repair 10.1 properly--and their reputation suffered as well. Hopefully the humiliation they went through at the hands of the Linux community made them learn to avoid repeating that behavior. I suspect this is the reason they took their time releasing 10.3--10 months for a minor release is a long time. They only took 6 months between 9.3 and 10.0, which was a major release (and a good one).
Old 10-09-2007, 10:08 AM   #15
FearFactory
Installed today, i'm posting from Suse 10.3 now and doing some updates. Need help to mount my both Windows disks, i did a costum partition and forgot to mount my other hd's
