#1 |
CUSL2 > GA-EP45-UD3P > ?
![]() Join Date: Apr 2001
P5B & 4GB Memory - Question
I had 2 x 1GB in the board and as expected, it showed 2048MB in the BIOS and in memtest. I put another 2 x 1GB in and instead of showing 4096MB the BIOS and memtest, it shows 3008MB and 3007MB, respectively. What gives?
I know I won't be able to utilize the whole 4GB in a 32 bit OS, but shouldn't it be visible/usable in the BIOS and memtest. ![]() edit: I tried re-seating all 4 sticks. Also confirmed that it shows 2048 if I use 2 x 1GB in either the black or yellow slots independently. help.
Current systems: Desktop: Antec SOLO II, Corsair TX650M, Asus F1A75-V Pro, AMD A8-3870K, 2x4GB Corsair Vengeance DDR3 1600, Asus EAH6670 1GB, Corsair Force GT 90GB SSD Antec SOLO, Corsair TX650, Gigabyte GA-EP45-UD3P, Intel Q9550, 4x2GB Corsair XMS2 DDR2 800, EVGA GTX560Ti SC 1GB, Asus U3S6, Corsair Force GT 120GB SSD Antec SOLO, Antec TruePower Trio 550, Gigabyte GA-EP45-DS3L, Intel E7200, 4x2GB Corsair XMS2 DDR2 800, Asus EAH4850 TOP 512MB Mobile: Asus Eee PC 1215B-PU17, AMD E-350, 2x4GB Corsair DDR3 1333, OCZ Vertex 2 120GB SSD Acer Aspire AS5253-BZ602, AMD E-350, 2x4GB Corsair DDR3 1333, Corsair Nova Series 2 60GB SSD Asus Eee PC 1000HE, Intel Atom N280, 1x2GB Corsair DDR2 667, OCZ Vertex 30GB SSD Last edited by PeterT; 10-12-2007 at 03:58 PM.. Reason: Added my troubleshooting attempts. |
| (Offline) |
#2 |
Re: P5B & 4GB Memory - Question
I found an option on the Northbridge page in the BIOS called "Memory Remap Feature". Default is disabled. I changed it to enabled and now it shows 4096MB. Is that it?
Current systems: Desktop: Antec SOLO II, Corsair TX650M, Asus F1A75-V Pro, AMD A8-3870K, 2x4GB Corsair Vengeance DDR3 1600, Asus EAH6670 1GB, Corsair Force GT 90GB SSD Antec SOLO, Corsair TX650, Gigabyte GA-EP45-UD3P, Intel Q9550, 4x2GB Corsair XMS2 DDR2 800, EVGA GTX560Ti SC 1GB, Asus U3S6, Corsair Force GT 120GB SSD Antec SOLO, Antec TruePower Trio 550, Gigabyte GA-EP45-DS3L, Intel E7200, 4x2GB Corsair XMS2 DDR2 800, Asus EAH4850 TOP 512MB Mobile: Asus Eee PC 1215B-PU17, AMD E-350, 2x4GB Corsair DDR3 1333, OCZ Vertex 2 120GB SSD Acer Aspire AS5253-BZ602, AMD E-350, 2x4GB Corsair DDR3 1333, Corsair Nova Series 2 60GB SSD Asus Eee PC 1000HE, Intel Atom N280, 1x2GB Corsair DDR2 667, OCZ Vertex 30GB SSD |
| (Offline) |
#3 |
| (Offline) |
#4 |
Thanks SRT. Yep, that was it: "The BIOS must support the memory remapping feature. The memory remapping feature allows for the segment of system memory that was previously overwritten by the Peripheral Component Interconnect (PCI) configuration space to be remapped above the 4 GB address line. This feature must be enabled in the BIOS configuration utility on the computer."
| (Offline) |
#5 |
I am planning on running XP Pro 32 bit. Do I have to disable the "Memory Remap Feature" to run a 32 bit OS?
TIA
| (Offline) |
#6 |
I dont see why you would have to, i would leave it enabled and installed xp.
| (Offline) |
#7 |
cool. will give it a shot. thx.
| (Offline) |
#8 |
OK... I need some more help with XP and 4GB.
With the memory remap feature enabled in BIOS, the XP system properties box shows 2GB. With the memory remap feature DISabled in BIOS, the XP system properties box shows 2.93GB. ![]() I tried the "3GB switch" detailed here, but see no difference: Memory Support and Windows Operating Systems Is it possible to get XP 32-bit to see and use all 4GB? How? I put Vista 64-bit on it to see if it would see and use all 4GB and it did, but I can't use that OS b/c it is an RC1 evaluation copy. And, I don't want to spend $190 on Vista Ultimate 64-bit any time soon. ![]() Tried google, lots of hits, but no joy. TIA for any insight.
| (Offline) |
#9 |
Found this:
The amount of RAM reported by the System Properties dialog box and the System Information tool is less than you expect after you install Windows XP Service Pack 2 It sheds some light on the subject, but doesn't answer my question, which is twofold: 1. How should I configure the BIOS and OS to be sure that the OS and apps can use all 4GBs? (I do not have the /PAE switch in the boot.ini, but it does show PAE in the system properties box.) 2. Is it impossible to get XP SP2 to display all 4GB? (I think the answer to this no.) TIA.
| (Offline) |
#10 |
A BIOS option that is not necessary, or does not fit the context, should never be enabled. Disabled the remapping bit when using an operating system that is only 32bits. As for you being able to use “all” of the 4GB when in 32bit mode, you are not paying close enough attention, and unfortunately the semantics of it all exacerbates it.
ALL of the memory is in use by Windows. However, since everything resides in memory, what is mapped to a device cannot be in use by an application at the same time (it will crash). This is why the PCI hole cannot be used as system memory. So Windows, Linux, UNIX, all of the operating systems capable of 32bits use all of the 4GB. You are not losing any memory and will not be able to make any changes unless you chose to use a 64bit operating system and enable 64bit processing and memory management. Do not make any other changes, leave the system as be. What you mainly read on the Internet concerning this matter is very much so incorrect. This is concerning PAE and the switches. Matter of fact you are most likely in PAE already, if you have a recent modern processer and SP2 for Windows XP. |
| (Offline) |
#11 |
Thanks for the reply shaihulud. I am trying to determine the correct settings to use in the BIOS and Windows and appreciate the help.
So, I should: 1. DISable the "Memory Remap Feature" in the BIOS (when I do this, the total memory reported is: 3008MB in BIOS and 2.93GB in Windows) 2. Remove the "/3GB" switch from the boot.ini Correct? ![]()
| (Offline) |
#12 | |
![]() Join Date: Mar 2001
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Use To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Feeling multicore elation? Remember this correlation: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
| (Offline) |
#13 |
You gonna throw that?
It's threads like this that make me love this place...
Create in me a pure heart, O God, and renew a steadfast spirit within me - Psalm 51:10 My goal in life is to be as good of a person as my dogs already think I am... Daywalker Studio: Software: Adobe Audition 3.0/Pro Tools LE 7.4/Acid Pro 6.0/Multiple VST, DirectX and RTAS plugins/Kontakt 3 Sampler/Windows XP Professional PC Hardware: D975XBX2-504/E6600/4x2GB Mushkin XP2-6400/eVGA 800GTX/HP f1905 19" flat panel/Echo Audio Gina24 Sound Card/2 Maxtor 6B300SO's/1 Maxtor STM500AS/1 Western Digital WD2500JD/PleXwriter Premium/Plextor 716A/Samsung LightScribe DVD burner/Logitech Revolution MX/Antec P-180b/PPC&C Silencer 610/Zalman CNPS9500 HSF Recording Hardware: Mbox 2 Factory Pro/Mackie SR24.4VLZ Pro Console/M-Audio Axiom 25 MIDI Controller/Audio-Technica 4033a microphone/Symetrix 528E/PreSonus Eureka/Mackie MR8 active monitors Game Machine: Gigabyte GA-X48-DQ6/E8400/4x2GB Mushkin XP2-8500/BFG GTX280/HP f2105 21" flat panel/Creative Labs X-Fi Elite Pro/Maxtor 6H500F0/Maxtor STM3320/Western Digital WD4000KD/Plextor 760A/Toshiba DVD-ROM/Zalman CNPS9700/Antec P-180/PPC&C Silencer 610/Ideazon Merc Stealth keyboard/Vista Business64 SP1 |
| (Offline) |
#14 |
Ive seen 32bit os show the full 4gb in windows, doesnt mean it will use the full 4gb but atleast you know its there.
| (Offline) |
#15 | |
Incorrect, memory is all address space (its logical partitioning). 4GB starts from 0x0000000 and the boundary is 0xFFFFFFFF. Mapped devices are within their boundary of this 4GB range, accordingly, when in 32bit mode. To say Windows is not using all the RAM is very much so incorrect. The mapped PCI I/O space has been addressed by the manager and the driver has reserved the area(s) for the activities within memory. Because of this, mapped I/O cannot be allocated as free physical or system usable memory.
Most think that since it cannot be allocated, or is not “seen”, et al, that Windows cannot use it. When the very space is and always has been in use. Quote:
| (Offline) |
| Thread Tools | |
| Display Modes | |
