Old 10-31-2007, 04:49 PM   #1
rock_abx
Question Help with DDR for P4B533-E
HI,
I have a P4B533-E mobo and have wanted to increase the RAM. I have 2 512s at the moment and have one slot left.
I tried to buy the DDR400 that the ones I have in are but was told they are not made anymore and that the DDR PC3200 is backward incompatible anyway.
I bought a 1GB stick of the PC3200 but when inserting it got a one long beep, space then another long beep etc. I tried it in every slot even by itself but still the same beep.
Sounds like it is NOT compatible.
Can I have some help here please?
Rock
Old 10-31-2007, 05:12 PM   #2
NBK
NBK's Avatar
Re: Help with DDR for P4B533-E
Originally Posted by rock_abx View Post
HI,
Rock
Hi
I have an ASUS P4B533-E too.
IIRC you can only use single sided DDR RAM in the 3rd slot.
HTH
NBK
Old 10-31-2007, 05:16 PM   #3
rock_abx
Ah Haaa.........
How crazy is that?
Can it be the the later DDR's like the 3200 as long as it is one sided?
Rock
Old 10-31-2007, 05:40 PM   #4
rock_abx
I just found this site where you can get a scan to see what RAM you have and what you can upgrade with.
This is my page for my P4B533-E
Memory upgrades from Crucial.com - Determine My Memory Needs
This says I am able to use the 3200's and that I should be able to insert the 1GB I have.
I wonder what the one beep is when i do this?
Maybe because it is 2 sided?
Rock
Old 10-31-2007, 06:54 PM   #5
NBK
NBK's Avatar
Hi
Only the 256Mb module is single sided...
NBK
Old 10-31-2007, 08:25 PM   #6
rock_abx
Oh well. I will try it again by itself. If it still gives one beep, it either is faulty or there is something Bios that stop a 1GB stick being used.
Anyone know whether that latter may be the case on the p4B533-E board?
Rock
Old 11-01-2007, 05:39 AM   #7
rock_abx
Well I tried again.. Took the 2 512's out and placed the 1GB 3200 in slot 1 and booted. It went fine so added a 512 in slot 2 and that too was fine.
But..
When I tried to add another 512 to slot 3, I got the long beep pause beep.
I tried 2 different 512 sticks and still the same.
Would there be a place in Bios that would cause this?
I looked but couldn't see anything.
It seems strange that slot 3 wont accept anything I have.
Any help please as I do need to kick this thing up to the 2GB max RAM
Rock
Old 11-01-2007, 12:13 PM   #8
NBK
NBK's Avatar
Angry Re: Help with DDR for P4B533-E
Hi
Check page 2-11 in your P4B533-E manual for further info on why you cannot install a double-sided DDR DIMM in slot 3.
HTH
NBK
Old 11-01-2007, 04:16 PM   #9
rock_abx
There you go! Thats what it is!
Slot 1 Dble side Slot 2 Dbl side Slot 3 ZIP
Slot 1 SingleS/DS Slot 2 SS Slot 3 SS
Guess I'll have to go buy another Dble side 1GB or 2x 512's Single sided.
Thanks for the help NBK
Got lotsa friends in NC altho' I'm here in Sydney OZ
Rock
Old 11-05-2007, 12:08 PM   #10
NBK
NBK's Avatar
Rock
Glad to be of help!!!
Old 11-07-2007, 03:38 AM   #11
Sir_JaKoNT|L
an ASUSBoard fanatic
Sir_JaKoNT|L's Avatar
but i thought it's best to always leave the last slot empty?
running rig
AMD ATHLON X2 4000+ AM2
Gigabyte GA-M61SME- SL2
2 x V-Gen DDR2 1GB RAM PC5300
WDC 160GB SATA2 8MB
Sony DVD R/W 20x
Enlight EN 4150 casing
Enlight True Power 420Watt PSU
Stick together team...
HTC Tytn II is the way!!!
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
© 2006 - 2009 ABXZone Forums | About ABX Zone Forums | Advertising Opportunities | Legal | A member of the Crowdgather Forum Community
