Old 11-29-2007, 02:32 PM   #1
Why is AVG so slow now?
I've been running AVG Free for a long time. It automatically downloads and scans each day.
It used to take a little over two hours to do a thorough scan of all my drives. Starting about a week ago, it now takes over seven hours! I didn't change any settings! What happened? Can I fix this? Was there a new more intensive update a week ago?
Old 11-29-2007, 02:36 PM   #2
SRTDodge05
SRTDodge05's Avatar
Re: Why is AVG so slow now?
Maybe try to un-install it and re-install it.
Old 11-29-2007, 03:52 PM   #3
Fragmentation?
Old 11-29-2007, 04:47 PM   #4
Originally Posted by k0NG0 View Post
Fragmentation?
Nothing that severe from one day to the next I would think. Triple the duration time?
AVG is one of the few programs that sits on my OS partition (10 gigs of files) and that gets defragged frequently.
Old 11-29-2007, 04:48 PM   #5
I was thinking of that but wouldn't I lose my scan history and such?
Old 11-29-2007, 06:44 PM   #6
SRTDodge05
SRTDodge05's Avatar
Not sure about that.
Old 12-18-2007, 06:48 AM   #7
I discovered the problem.
At the bottom of the AVG Scanning Progress window it shows the file that the antivirus program is currently scanning. Almost everytime I looked the same file was showing there. So I searched for it. The file did not exist. I opened up the ReCycle Bin and there it was. So I cleared the Recycle Bin and now all is back to normal scanning times.
Old 12-18-2007, 07:33 AM   #8
That's a pretty huge bug. You should let Grisoft know about it.
Old 12-19-2007, 11:03 AM   #9
MrSeanKon
Banned
I have not encountered
something like that. Basically I turn-off the automatic scanning and I perform it once per month (for example).
