Old 12-24-2007, 01:08 AM   #1
Linux user
yamawho's Avatar
Anyone using Parallels workstation for windows ?
I was thinking that this may be an option for me since there are alot of distros I want to try ...
I read somewhere that you can run an ISO without burning it.
Looking for feedback
Old 12-24-2007, 12:52 PM   #2
Vista x64 User
Re: Anyone using Parallels workstation for windows ?
I use Virtualbox 1.5.2. I have run Ubuntu on it with no issues. They don't specifically list which distros they support, their setup is fairly generic by kernel. I do not believe they support the absolute newest test kernels yet.
Parallels is the only virtualization software I am aware of that has no free version. This is kinda lame.
For max flexibility you may want to consider VMWare since their solution can run 64-bit clients, if you want to try 64-bit variants of Linux.
The ability to mount ISOs directly is in most virtualization products.
