Old 01-11-2008, 07:10 AM   #1
shaihulud
shaihulud's Avatar
I need anyone with an Athlon 64 and a nForce3 or higher to execute lspci –vvv
I was looking at a recent update to the kernel and wondering something. I noticed a discrepancy with the HyperTransport information and may need to report a bug. If anyone with the following core logic(s) on any distro do this command: lspci –vvv. Cut and paste the information here for me to parse and also the distro you use would be helpful too. Note, you may need to be root to perform this command. A simple su – command and then password will get you to the point to execute.
Old 01-11-2008, 02:12 PM   #2
shaihulud
shaihulud's Avatar
Re: I need anyone with an Athlon 64 and a nForce3 or higher to execute lspci –vvv
Never mind the issue is resolved now.
