Old 01-14-2008, 11:17 AM   #1
DS_abx
AMI Full Screen BIOS Logo
Two weeks ago I posted a question regarding full screen logos in Award BIOSs. Has anyone had any success adding a full screen logo to an AMI Bios. If so, do you have any tutorials or software that would be helpful? Thanks. Oh yeah, this is for an ASUS P4P800 SE motherboard.
Asus CUSL2
Pentium III 866Mhz
384MB Crucial
Windows XP Home SP2
Ubuntu 7.10
20GB WD ATA66 7200RPM HD
Aopen 16X DVD
Lite-On 40X12X48X CD-RW
ATI Radeon 7000
Old 02-15-2008, 12:21 AM   #2
spinmac
Re: AMI Full Screen BIOS Logo
I was able to replace the MSI full screen bios logo on my Hetis 965 using an AMI bios tool called mmtool v3.12. I extracted a module named OEM logo and found it to be a pcx image, 640x480@256color. I then replaced the OEM logo module with my own image converted to pcx format. I used IrfanView to do the conversion.
For your motherboard you could use Asus MyLogo for a custom bios logo.
Old 02-23-2008, 11:20 AM   #3
nationapn
Hey SpinMac,
Thanks for the info...I'm trying to change the boot logo on my MSI GM965. I just have a couple questions. I downloaded MMTool 3.12 and found the OEM Logo in my bios file and extracted it. I then changed the file extension to a variety of file types to determine what it was. I tried PCX first since that's what you said it was, but it wouldn't open in Adobe Photoshop under any of the commonly known image extensions...Am I doing something wrong?
I appreciate your help! You're the first person I've found with success altering the boot logo on the new AMI Bios.
Old 02-24-2008, 10:32 AM   #4
smarty8
Hi spinmac. Me too interesting for change AMI logo from 1A module.
I tried supplement extracted 1A module with .pcx extension and viewed this one by IrfanView - nothig intelligible. Then i gave header from genuine .pcx file and replace 1A module header - nothig intelligible. Can you issue your 1A module header for compare.
It's my in hex:
Code:
Offset      0  1  2  3  4  5  6  7   8  9  A  B  C  D  E  F
00000000   47 52 46 58 01 01 08 00  00 00 00 00 4E 00 00 00   GRFX.....N...
00000010   00 00 02 01 4C 00 00 80  00 00 10 00 00 49 4D 41   ..L..Ç....IMA
00000020   00 00 00 0E 16 29 0E 1C  2D 14 2B 10 14 2B 0E 0F   ...)-++
00000030   14 13 14 21 2F 30 30 30  16 23 31 16 2F 0E 23 00   !/000#1/#.
00000040   02 35 00 0C 2D 2B 21 3D  39 27 30 30 30 3F 3F 3F   5.-+!=9'000???
00000050   00 00 53 49 4D 41                                  ..SIMA
When finde right entry point?
TIA
Old 02-24-2008, 06:03 PM   #5
smarty8
Smile Re: AMI Full Screen BIOS Logo
Oh yes!!!
I resolved this problem.
Thanks and respect Veit Kannegieser ( veit@kannegieser.net ) for him nice stuff ami_ppm.com ( httр://kannegieser.net/veit/programm/ami_ppm.arj )
Spinmac's method applicable for AMI BIOS core 7 or earlier,probably.
But since core8 AMI use GRFX format for small logo into 1A SMALL LOGO(S) module.
Veit's utility may convert GRFX to PPM then IrfanView in any format.
Enjoy
Old 03-13-2008, 04:23 AM   #6
Heather_88
hi all the expert,
I need your help. I have tried to change logo for my motherboard that used AMI bios File, and succesed but when I was changing the format image logo file from pcx to bmp, and then flash into the bios motherboard, the motherboard is blank.
Does anyone can help me what I have suppose to do now?
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
© 2006 - 2009 ABXZone Forums | About ABX Zone Forums | Advertising Opportunities | Legal | A member of the Crowdgather Forum Community
