Old 01-20-2008, 05:22 PM   #1
FearFactory
The FC.Porto dragon!
FearFactory's Avatar
Wine not working on Suse 10.3
I installed Suse 10.3 today but i can't get Wine to work. It installs fine on Yast but i can't find it on the K menu..
AMD Phenom II X2 555BE 3.2Ghz AM3 (OC x4 3.7Ghz),CoolerMaster Hyper 212 Plus, Asus M5A99X Evo , 2x 4GB DDR3 1600Mhz Corsair Vengeance, VGA PowerColor HD6950 2GB DDR5, Asus DVDRW, Seagate 2TB SATA, Seagate 500 SATA, PSU Nox Hummer M 650W, Asus ML239 23' IPS
Old 01-20-2008, 11:28 PM   #2
swannema
swannema's Avatar
Re: Wine not working on Suse 10.3
It won't show up till you have installed a windows program. Did you try to install one, just try to run an exe file for fun.
Old 01-21-2008, 03:21 PM   #3
FearFactory
Tried with DVDFab HD, clicking on it did nothing, i had to "open with" and use the command "wine". This way i was able to install DVDfab but theres no Wine program group on the K menu. I need it to configure my dvd-rom drives because DVDFab is not detecting them.
