Old 02-23-2008, 02:05 AM   #1
DavidNJ
Artic Silver 5 vs. Artic Cooling MX-2
In a nutshell, reviews indicate MX-2 is a degree or two, measureable but just, cooler than Artic Silver 5. However, there may be another reason.
The reviews say MX-2 is 'runnier'. Artic Silver recomments 'tinning' which to them is a surface prep where you force AS5 onto the surface hard and then wipe it off. It remains in the voids of the surface roughness. AS5 is then applied normally (a thin stripe across the cores.
Now, could the MX-2 advantage in the reviews be that it comes closer to the 'tinning' without actually preparing the surface? Does preparing the surface remove the MX-2 advantage?
Gigabyte GA-P35-DS3P rev 2.1
Q6700 G0 360Mhzx10@1.48v
Modified Swiftech H20 220 Compact
ECS 8800GT with Accelero at 720/1890/2200
4 x 2048 OCZ DDR800 Platinum at 2.0v & 456Mhz (PC913)...MCH +.25v
1000w Cooler Master PSU (inlet ducted underneath the case)
4 x 500GB, 1x750GB disk on the Gigabyte SATA
2 1tB WD MyBook Home eSATA drives for backup
Cooler Master CM690 case
with 4 AeroCool 140mm fans (two top, one side, one bottom, second side didn't clear the HSF
Old 02-23-2008, 05:02 AM   #2
Re: Artic Silver 5 vs. Artic Cooling MX-2
Do you have a link to the review that you mention?
Please note: any advertising within this post has been placed there by the site owner and NOT by me! ***
"To Boldly Go..."
Old 02-23-2008, 05:05 AM   #3
polonyc2
Legacy
polonyc2's Avatar
here's one review...
Arctic Cooling MX-2 Thermal Paste :: TweakTown
and another...
Reviews | Arctic Cooling MX-2 - APH Networks
ASUS P6X58D Premium ***** MSI GTX 580 Lightning 1.5GB
Intel i7 980X (Gulftown)
***** Noctua NH-U12P SE2
G.Skill PI Series 6GB (3 X 2GB) DDR3 1600 7-8-7-24 *****
G.Skill Falcon I 256GB SSD
Lian Li PC-A70B (black)
***** Corsair HX850W
Lite-On IHAS424
***** NEC 2490WUXi LCD
Windows 7 Home Premium SP1 64-bit *****
Old 02-23-2008, 10:17 AM   #4
iMogal
Zoom Zoom...
iMogal's Avatar
I've used both MX-2 and AS Ceramic.
But, not on the same system.
For ease of use, MX-2 was easier to apply.
(I bought 2 bottles just cuz of reviews I've read)
I don't think you could go wrong with either one.
SilverStone LG-08
Asus P5E-VM HDMI
Intel e8400 O/C'd 3.88Ghz
2x2Gb G.Skill DDR2-1000 (5,5,4,14) (2:3 533Mhz)
WD1001FALS Caviar Black 1TB
ATi 5850
Corsair HX620 Modular PSU
Dell UltraSharp 2407FPW
Monsoon MM-700 2.1 Speakers
Old 02-23-2008, 01:17 PM   #5
wonderwrench
wonderwrench's Avatar
I have been hearing good things about Masscool Shin-Etsu x23.
Reviews show it blowing everything else away. I have also read that both Intel and AMD retail heat sinks come with some form of Shin-Etsu compound. I would have tried it out my self but I already have enough AS5 to last me years. Its hard to find Shin-Etsu x23 for sale also. Review Thermal Interface Material Comparison - Xtreme CPU
Old 02-24-2008, 10:49 PM   #6
DavidNJ
I just installed a Xigmatek 1283 with AS5. I don't even know how AS5 compares to AS Ceramique.
Never heard of the Shin-Etsu x23, but there appear to be 2 online retailers...the manufacturer and CrazyPC. $8.00 for a 1gm syringe.
The cost of the thermal paste is so small compared to the parts it is used between, I don't consider it worth worrying about. However, small differences in tests...especially one test...is not statistically significant.
Based on the resolution of measurement, the AS Ceramique has the same performance...and is readily available. Why aren't we all using it?
Also...back to my original question: is the difference in prep? That is, does preparing the surface with 'tinning' improve the AS to be competitive with the others...which may be less viscous?
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
© 2006 - 2009 ABXZone Forums | About ABX Zone Forums | Advertising Opportunities | Legal | A member of the Crowdgather Forum Community
