Old 05-20-2008, 07:42 AM   #1
drkameleon
FoldWatcher is out!!! The ultimate Folding@Home Monitor...
FoldWatcher
is an integrated monitoring environment for Folding@Home designed for Linux and *nix Systems, which is intended to be easy-to-use and provide a flexible, customiseable and "user-friendly" environment for reviewing the status of active F@H clients. Foldwatcher is FREE software released under the terms of the GNU GPLv3 License. It is entirely coded in C++, making use of Qt (version 4.3) Libraries, which may allow a future easier porting to Windows or MacOS platforms.
* It allows to quickly check the progress of up to 100 clients and retrieve valuable information from the Work Unit being processed such as protein name, project number, Run/Clone/Generation and many more.
* It makes use of Ivoshiee's 'finstall script' in order to facilitate the installation of either simple or SMP Folding@Home clients, on i386 and amd64 machines.
* Combined with a powerful calculation algorithm, it may also provide estimations on the completion of a WU as well as indications of all Folding@Home clients' performance (secs/frame, frames/h, frames/day, points/h, points/day-PPD).
* Projects and project information is stored in a maintainable database to exclude the need of a working internet connection.
* It can fetch your personal stats or your team's stats and show them into the main window, enabling even printing and exporting them to a PDF file.
* Along with the 'finstall' script, it can be used to start or stop the execution of Folding@Home clients.
* Moreover, it integrates the ability - using either the RasMol Open-Source 3D Molecule Viewer or the JMol WebSite's Java Applet - to view the protein being folded.
Download and Installation instructions at my BLOG. ----> http://kameleon-nest.blogspot.com
I desperately need your comments and I hope you' ll love it...
Old 05-20-2008, 08:34 AM   #2
rachael24
Re: FoldWatcher is out!!! The ultimate Folding@Home Monitor...
Thanks for the post...I will check it out and leave ya some feedback
Owner of 3 internet franchises and computer enthusiast.
Old 05-20-2008, 08:09 PM   #3
drkameleon
First Windows release is out as well....
I hope you ll check it out too...
Thnx
My BLOG ----> kameleon-nest.blogspot.com
Old 05-21-2008, 12:25 AM   #4
zsaz1029
zsaz1029's Avatar
If this gets a good grade from any regular members who decide (dare) to try it, then I might also. No offense drkameleon.
Spaz
"A scar is never the same as good flesh, but it stops the bleeding." -- FitzChivalry Farseer (Assassin's Quest by Robin Hobb)
"Only my pain is more silent than my anger." -- Amber (The Liveship Traders by Robin Hobb)
Old 05-21-2008, 10:51 AM   #5
drkameleon
No offence, of course.
However, I desperately need some testers...
I'm always open for comments, suggestions and bug reporting....
Old 05-21-2008, 12:16 PM   #6
Gorganzola
Gorganzola's Avatar
I made your link in the first post linkable for you drkameleon. Hopefully this works out well for the community.
TTFN.
A. One.
You can
in public.
Old 05-21-2008, 01:38 PM   #7
drkameleon
Thnx!!!
Keep testing and... FOLDING!
Old 01-21-2009, 09:41 AM   #8
Somehow I missed this, I'll take a looks as soon as I can.
