Old 06-18-2008, 08:14 AM   #1
Anarchi
Anarchi's Avatar
Speed Test utility to test USB Key / SD card performance?
Is there a utility to test the Read/Write performance of removable storage?
Something similar to the HDD ones such as HD Tach.
Tried looking in google, couldnt find anything.
Mobo: Asus P5B Deluxe
CPU: Core 2 Duo E6750
Memory: 4GB DDR800
Video: GeForce 260GTX 896MB
OS: Windows 7 Pro 64bit RTM (and XP Pro)
Sound: Auzentech Prelude X-Fi
Old 06-18-2008, 09:51 AM   #2
jaketerminate
Maximum Post
jaketerminate's Avatar
Re: Speed Test utility to test USB Key / SD card performance?
Try:
USB.org - Tools
or
USB Testing Software: USBTester
Hope this helps!
"Mozart" Rig #1
Case: Thermaltake Mozart TX
Mobo: Asus P5N-E
CPU: Intel Core 2 Quad Q6600 2.4ghz
Memory: 4GB (2x 2GB) G.Skill DDR2
Hard Drive: 320 GB Western Digital 7200 RPM
Video Card: EVGA Nvidia 9800GX2 1GB (512MB per GPU)
Power Supply: 600W OCZ StealthXStream
OS: Windows XP Homee Edition and Ubuntu Linux x64
Monitor: 22" Westinghouse LCD and 2 Dell CRTs
HP G60t
CPU: Intel Pentium 2.0ghz
Memory: 4GB
Hard Drive: 250GB 5400RPM
GPU: Intel Graphics Media Accelerator 4500M
OS: Windows 7 Ultimate Build 7000 Beta + Ubuntu Linux
HP Pavillion tx 2000z Tablet
CPU: AMD Turion x2 2.1Ghz
Memory: 3GB
GPU: ATI Radeon 3200 64mb
1TB Seagate External Backup Drive
Old 06-18-2008, 10:11 AM   #3
HD Tune will do that. I have used it via firewire, and I assume it would work similarly via usb. I would think many of the other standard hd speed utilities would be able to also. They will see the drive through Windows, just as they would see an internal drive.
The differences are that SMART information will not be visible, and of course the measured speed will be reduced or limited by the interface's data rate. But that is presumably what you want to measure, rather than the potential speed of the physical drive itself that cannot be realized through the external interface.
Edit: When I wrote the above I hadn't seen your subject line indicating that you were referring to solid state external storage (as opposed to usb or firewire hard drives). But I just tried HD Tune to benchmark a memory stick and an SD card, and it worked fine.
Old 06-18-2008, 07:15 PM   #4
Anarchi
Anarchi's Avatar
Ok thanks for that, I'll try HD Tach since I would like to test the speed of an SD card at this point.
Memory: 4GB DDR800
Old 06-18-2008, 07:22 PM   #5
You're welcome! Note though that I was referring to HD Tune, which is not the same as HD Tach. If HD Tach doesn't work for you, try HD Tune which is available here:
HD Tune
Old 06-19-2008, 12:04 AM   #6
Anarchi
Anarchi's Avatar
Didnt realise that lol. Thanks again.
Memory: 4GB DDR800
Old 06-19-2008, 03:29 AM   #7
Anarchi
Anarchi's Avatar
I used a neat utility called Crystal Disk Mark to test the speed.
My SD card is officially the slowest in the world lol
Included the results of a 750GB perpendicular WD HDD for an unfair comparison
Memory: 4GB DDR800
Old 08-10-2008, 03:42 AM   #8
Vlad0
Sony 2GB SDCard
CrystalDiskMark 1.0 (C) 2007 hiyohiyo
Sequential Read : 2.831 MB/s
Sequential Write : 3.061 MB/s
Random Read 512KB : 2.826 MB/s
Random Write 512KB : 0.526 MB/s
Random Read 4KB : 2.390 MB/s
Random Write 4KB : 0.025 MB/s
Date : 2008/08/10 9:51:58
My laptop HDD 5400rpm, ATA, 80GB, NTFS
Sequential Read : 27.707 MB/s
Sequential Write : 23.504 MB/s
Random Read 512KB : 19.439 MB/s
Random Write 512KB : 11.592 MB/s
Random Read 4KB : 0.600 MB/s
Random Write 4KB : 1.215 MB/s
Date : 2008/08/10 9:57:16
Old 12-04-2009, 08:59 AM   #9
postulio
hello. i found this thread googling for a way to speed test my micro SD card.
thank you so much for the CystalDIskMark program. it is awesome
for reference:
RiData 16GB Class 6 Micro SD card from newegg ($49)
Fat32 format used on a multi memory card reader (USB)
CrystalDiskMark 2.2 (C) 2007-2008 hiyohiyo
Sequential Read : 19.701 MB/s
Sequential Write : 6.655 MB/s
Random Read 512KB : 19.475 MB/s
Random Write 512KB : 1.088 MB/s
Random Read 4KB : 3.464 MB/s
Random Write 4KB : 0.033 MB/s
Test Size : 5 x 100 MB
Date : 2009/12/04 9:58:38
also:
Sequential Read : 19.715 MB/s
Sequential Write : 6.868 MB/s
Random Read 512KB : 19.352 MB/s
Random Write 512KB : 0.957 MB/s
Random Read 4KB : 3.415 MB/s
Random Write 4KB : 0.053 MB/s
Test Size : 2 x 1000 MB
Date : 2009/12/04 10:15:31
Old 12-04-2009, 06:32 PM   #10
to the zone.
Old 12-14-2011, 12:40 PM   #11
jimmyemunoz
Exclamation Re: Speed Test utility to test USB Key / SD card performance?
All tested on my Dell Laptop's built in memory stick reader (1000MB, 1 Run through, Crystal Disk Mark v3.0.1)
A-Data
8GB Class 10
Sequential Write: 18.65
Sequential Read: 18.43
4K Random Write: 0.009
4K Random Read: 2.917
A-Data
8GB Class 4
Sequential Write: 4.8
Sequential Read: 19.49
4K Random Write: 1.271
4K Random Read: 3.161
Sandisk
8GB Class 4
Sequential Write: 5.566
Sequential Read: 10.17
4K Random Write: 0.930
4K Random Read: 2.353
Samsung
8GB Class 2
Sequential Write: 5.603
Sequential Read: 14.43
4K Random Write: 0.021
4K Random Read: 2.345
Top Ram
8GB Class 6
Sequential Write: 13.20
Sequential Read: 19.32
4K Random Write: 0.006
4K Random Read: 3.30
OK, guys, I hope this helps in picking a flash card. Personally, the Top Ram class 6 and A-Data class 4 look like winners.
Last edited by jimmyemunoz; 12-14-2011 at 02:04 PM.. Reason: added the utility I used and specifics
