Old 07-13-2008, 08:01 PM   #1
Ford Freak
Ford Freak's Avatar
Hd4870
I decided to give the GPU client a go since I have the 4870 installed now. I'm suprised at how fast it folds. It had 1 WU done about 4 hours after installing the client. I'm not sure if I'll leave it installed though.
Old 07-15-2008, 04:52 PM   #2
Griff
Griff's Avatar
Re: Hd4870
Yes the GPU client folds very fast. Have you had any problems with it?
Obsidian 550 Corsair Case
Asus Motherboard P8Z77-V PRO
Intel i7-3770K Unlocked
Arctic Cooling Freezer 13
Samsung 840 EVO SSD For O/S
LG BlueRay Burner
Seagate1TB SATA for Photos
Built in Card Read
Win10 Pro
Old 07-15-2008, 09:17 PM   #3
Ford Freak
Ford Freak's Avatar
Re: Hd4870
I ran it for a little while and it worked fine. I decided to stop using it though. That thing cranked out a lot of heat. I might run it in the winter though.
