Old 07-17-2008, 04:27 PM   #1
Pasch
Pasch's Avatar
c++ cout: don't trim "zero" bytes
Hi there,
I'm implementing SHA256 in C++, but I've got a tiny problem. I'm using cout to output the result of the hash operation in hex, but sometimes a "zero" byte has to be printed by cout. By "zero" byte I mean a byte that has 00 as its hexadecimal value. When a byte like that occurs, cout just prints a single 0, however I want it to print 00, not the shorthand single 0. Does anybody know of a way to force cout to do this?
I would be very happy with any help.
Regards.
Old 07-17-2008, 05:15 PM   #2
Re: c++ cout: don't trim "zero" bytes
Quick and dirty answer:
Code:
cout.setf(ios::hex, ios::basefield); //set to display stuff as hex
cout << setw(2) << setfill('0') << whatever << endl;
Requires you to include <iomanip>.
Old 07-17-2008, 05:29 PM   #3
Code:
#include <iostream>
#include <iomanip>
using namespace std;
int main() {
  unsigned char bytes[4] = {0, 1, 0x09, 0xfe};
  for (int i = 0; i < 4; ++i) {
    cout << setw(2) << setfill('0') << (int)bytes[i] << endl;
This yields:
00
01
09
fe
Old 07-27-2008, 04:53 PM   #4
Pasch
Pasch's Avatar
Originally Posted by k0NG0 View Post
Code:
#include <iostream>
#include <iomanip>
int main() {
This yields:
00
01
09
fe
Thank you for your reply! I'm sorry for replying so late, for some reason e-mail notification didn't work. In the meantime I wrote myself a nice function that makes the hex strings for me, as I needed to return them as a string rather than print them to the screen in the eventual program, but I'll be sure to remember this for the future. The project worked out by the way, I've got all SHA versions up and running now and giving correct results. Thanks again for the reply!
Old 08-22-2016, 08:36 PM   #5
Spam
