Old 08-17-2008, 05:00 PM   #1
NBK
NBK's Avatar
Question Firefox 3.0 and the awesome bar???
Hi
How does one delete the entries in the Awesome Bar and keep them out?
TIA
NBK
Processor: Intel Core 2 Quad Q9650 3.0GHz****RAM: G.Skill DDR2-1066 4x2048
Motherboard: ASUS Maximus Formula rev. 103g****BIOS: Rampage Formula 1001
Video: AMD Radeon HD 7950****Case: Lian-Li PC-60PlusII Black
Sound: Creative Sound blaster X-FI Fatal1ty****PSU: Corsair 750watt
HSF: Zalman 9700 LED****Hard Drive [OS and Apps]: WD 1Tb
Hard Drive [Media]: WD 2Tb****Hard Drive [Backup]: WD 250Gb****Hard Drive [Storage] WD 1Tb
Card Reader: Koutech IO-RCM621
SATA Blu Ray Burner: Lite-On iHBS312 2
SATA DVD Burner: Samsung SH-S243N
Sound Card: Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
Monitor: HP w1907 19"
OS: Windows 7 SP1
MacBook Pro 17" [June 2009] 2.8GHz* 500Gb 7200rpm*MacOS X 10.6.4
Other Components:
APC Back-UPS RS 1500VA
Brother HL-5250DN Laser Printer****HP Photosmart C6280 All-in-One****Dlink DIR655****Canon Vixia HV30
Old 08-17-2008, 11:26 PM   #2
Re: Firefox 3.0 and the awesome bar???
To keep them out isn't possible that I know of. You delete stuff from history using Shift+Del.
Old 08-18-2008, 07:02 AM   #3
Baehemoth
You can keep anything from showing up at all while you are entering a new address by typing about:config in the address bar, scroll down to the browser.urlbar.maxRichResults and change the value from 12 to 0. Restart Firefox to show the changes.
Gigabyte GA-K8N Ultra-SLI |AMD X2 4800+ |eVGA 7800GTX | Antec TruePower 550w |Patriot 4g PC3200 |Seagate 500g Baracuda|
Laptop:
Lenovo T61|Intel Core2Duo T8100 @ 2.10Ghz|2g RAM| 120g SATA
Old 08-18-2008, 07:36 AM   #4
NBK
NBK's Avatar
Hi Baehemoth,
I found a solution here too! 9 tweaks for Firefox 3’s location bar - Mozilla Links
NBK
OS: Windows 7 SP1
Other Components:
Old 08-18-2008, 07:58 AM   #5
Baehemoth
No problem. I was trying to find a solution for that as well. Nice find on the article!
Laptop:
Old 09-02-2008, 12:42 AM   #6
NBK
NBK's Avatar
NBK
OS: Windows 7 SP1
Other Components:
Old 09-02-2008, 08:56 AM   #7
WhiteEclipse
WhiteEclipse's Avatar
Good link!
