Old 10-14-2008, 10:35 AM   #1
Drufuss
Drufuss's Avatar
Do you need a fast internet connection for Linux?
Well, the answer for me is "Yes".
I'm finally really enjoy using linux (openSuse 11.0 64bit in my case).
And this is not only to the fact that the ati drivers are easy to install nowadays (somehow i always got them running sooner or later).
It is mostly because i switched from ISDN to ADSL2+. Now i can easily install or update applications, drivers, kernel etc. from home, without waiting hours and days for downloads to finish or take notes of what i might need and download it at work.
With a working and fast internet connection a full install of openSuse (plus some basic applications, drivers, upgrades, updates, patches and additional setups) takes about the same time as a new Vista install (plus some basic ....).
Greetings
Dru
System specs:
Asus Maximus VI Formula (watercooled)
Core i7-4790K 4.00 GHz (watercooled)
4 x 8GB DDR3-Ram PC3-2400 Kingston Beast XMP
3 x Samsung 840 EvoO 1 TB
Gigabyte GeForce GTX970 G1 Gaming (watercooled)
Soundblaster ZxR, Hauppauge HVR4400 DVB-T/S2, Logitech Z-5450 5.1 THX Wireless
Logitech DiNovo MediaDesktop 2.0
Enermax Platimax 750W
Pump: Laing DDC2
Radiator: Watercool Mo-Ra 3 420
Case: Cooltek Antiphon
Windows 7 Ultimate 64bit retail
CUSL2-C ruled! ..äh... RulEd!
Time flies like an arrow,
fruit flies like a banana.
Old 10-14-2008, 03:19 PM   #2
Cogar
Level 16, lawful good
Cogar's Avatar
Re: Do you need a fast internet connection for Linux?
Hi Dru,
I am glad that things are working out for you with regard to your Internet connection. As I recall, it has been a thorn in your side for a few years (at least).
With regard to your question, I suspect that Linux does not require a different connection than Windows does. The only apparent difference is that on a Linux machine an update typically updates the operating system and all of the applications included in that distribution. This is different from Windows, which only updates the operating system itself, and each application is updated separately. My two cents.
Old 10-14-2008, 05:58 PM   #3
Drufuss
Drufuss's Avatar
Hi Cogar,
yes i'm very happy now that my pc has a fast connection to the www.
One thing i like about openSuse (or linux generally) is that you can handle about all updates (and most upgrades) with one single application. Once all repositories are included (from which you downloaded/installed the program in the first place) every update is only 1 click away. And you can still choose what app. does the right things the right way for you (almost) without any costs. As soon as you have real acces to opensource you never want to miss it.
Greetings
Dru
P.S.: openSuse 11.1 beta's are avialable, but be warned. Some earlier build was able to kill network adapters.
System specs:
Pump: Laing DDC2
Old 10-15-2008, 12:05 PM   #4
Cogar
Cogar's Avatar
Yeah--I heard about that. I am interested in 11.1 when the final release is available. Based on the road maps I have seen, I think that is supposed to be in November. I hope it is good. (For now, I am still happy with Fedora 8, so I am in no hurry.)
Old 10-15-2008, 12:36 PM   #5
FearFactory
The FC.Porto dragon!
FearFactory's Avatar
There are others distros with that problem, like the latest Ubuntu beta version. But it only happens with Intel network cards.
AMD Phenom II X2 555BE 3.2Ghz AM3 (OC x4 3.7Ghz),CoolerMaster Hyper 212 Plus, Asus M5A99X Evo , 2x 4GB DDR3 1600Mhz Corsair Vengeance, VGA PowerColor HD6950 2GB DDR5, Asus DVDRW, Seagate 2TB SATA, Seagate 500 SATA, PSU Nox Hummer M 650W, Asus ML239 23' IPS
Old 10-15-2008, 05:16 PM   #6
Wow, you're finally off ISDN - congrats!!
Old 10-16-2008, 02:10 AM   #7
Drufuss
Drufuss's Avatar
Yes, i finally did it. Well, had to because my ISP (like all others here in austria) no longer supports ISDN for home user.
Within the last year the monthly rates for internet+telephone contracts (no limit on both) have fallen, download speeds have risen and support and quality have improved so i was easily convincend to change. Now the benefits finally justify the costs imho.
I'm looking forward to november and the final release of 11.1 too.
This will be the first linux distro/version i can download myself at home.
Greetings
Dru
System specs:
Pump: Laing DDC2
