Old 11-23-2008, 12:13 PM   #1
NBK
NBK's Avatar
Unhappy Cannot delete folder...
Hi
Sometimes i cannot delete a folder in Windows XP SP3. I get the following error message and have to log out and log back in to Windows to delete it. Is there anyway to solve it???
NBK
Processor: Intel Core 2 Quad Q9650 3.0GHz****RAM: G.Skill DDR2-1066 4x2048
Motherboard: ASUS Maximus Formula rev. 103g****BIOS: Rampage Formula 1001
Video: AMD Radeon HD 7950****Case: Lian-Li PC-60PlusII Black
Sound: Creative Sound blaster X-FI Fatal1ty****PSU: Corsair 750watt
HSF: Zalman 9700 LED****Hard Drive [OS and Apps]: WD 1Tb
Hard Drive [Media]: WD 2Tb****Hard Drive [Backup]: WD 250Gb****Hard Drive [Storage] WD 1Tb
Card Reader: Koutech IO-RCM621
SATA Blu Ray Burner: Lite-On iHBS312 2
SATA DVD Burner: Samsung SH-S243N
Sound Card: Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
Monitor: HP w1907 19"
OS: Windows 7 SP1
MacBook Pro 17" [June 2009] 2.8GHz* 500Gb 7200rpm*MacOS X 10.6.4
Other Components:
APC Back-UPS RS 1500VA
Brother HL-5250DN Laser Printer****HP Photosmart C6280 All-in-One****Dlink DIR655****Canon Vixia HV30
Old 11-23-2008, 12:17 PM   #2
NBK
NBK's Avatar
Re: Cannot delete folder...
Oops! Here is the attachment...
NBK
OS: Windows 7 SP1
Other Components:
Old 11-23-2008, 03:16 PM   #3
Rick_EE
Sent from my PC
Rick_EE's Avatar
Sounds like something is staying resident in memory. Logging out will take it out and release the file. It that case, memtest must be leaving something.
Old 11-23-2008, 03:22 PM   #4
polonyc2
Legacy
polonyc2's Avatar
chant Abracadabra right before deleting it...
other then that I agree with Rick EE
Intel i7 980X (Gulftown)
***** Noctua NH-U12P SE2
G.Skill Falcon I 256GB SSD
Lian Li PC-A70B (black)
***** Corsair HX850W
Lite-On IHAS424
***** NEC 2490WUXi LCD
Windows 10 Home 64-bit *****
Old 11-23-2008, 04:57 PM   #5
NBK
NBK's Avatar
Hi Rick_EE,
I will run memtest on each of my sticks and see what happens
NBK
OS: Windows 7 SP1
Other Components:
Old 11-23-2008, 05:16 PM   #6
Gorganzola
Gorganzola's Avatar
Running memtest won't fix the issue. I've had the issue once before and it would occur with various files and folders. Very irritating. I eventually re-installed the operating system. Didn't feel like troubleshooting the issue. However, booting to safe mode may well allow you to remove the file otherwise if you really need to delete it.
TTFN.
A. One.
You can
in public.
Old 11-23-2008, 07:19 PM   #7
Rick_EE
Sent from my PC
Rick_EE's Avatar
Originally Posted by NBK View Post
Hi Rick_EE,
NBK
I meant, based on your screenie, the OS thinks a file in the memtest directory is open. If you ran memtest, maybe something stayed resident in memory. Or, like gorgonzola said, it just thinks so.
It has nothing to do with the physical memory.
Old 11-23-2008, 07:31 PM   #8
CommandrX
CommandrX's Avatar
I use Unlocker to delete stubborn files. You might want to give it a try.
Also moving the file and/or folder to the desktop allows for the file deletion do to changes of file/folder permissions. This method works great for removing the pesky Flash9.ocx file.
GAMING RIG: P4 3.4GHZ 1MB L2, Intel D875PBZ REV. AA C27085-304, 4GB HyperX 2.5-3-3-5, BFG 7800GS OC 256MB 425x650MHZ, (2) 500GB Barracuda 32MB cache in Raid 0, Antec NeoPower 550W, Lian Li PC-75, CPU Cooling-Scythe MUGEN, 42" Plasma (1080i)
Old 11-24-2008, 02:17 PM   #9
NBK
NBK's Avatar
Hi all,
Thanks for the ideas!!!
NBK
OS: Windows 7 SP1
Other Components:
Old 03-20-2009, 06:20 AM   #10
NBK
NBK's Avatar
Cool Re: Cannot delete folder...
Hey CommandrX! The problem came back and 'Unlocker' worked like a charm...
NBK
OS: Windows 7 SP1
Other Components:
Old 03-20-2009, 12:23 PM   #11
rjs735
Virus? What I am not sick
rjs735's Avatar
Yes usually the reason you can't delete something is because of use or being locked which didn't release when the task ended. Like when a program fails to close and you have to invoke task manager to kill the task because it's hung.
Optorite CDRW WD 40GB
All systems are networked
Old 10-12-2009, 01:04 AM   #12
simplyjoy
Banned
it sounds that your computer have virus in it ,and i suggest you have your disk formatted.
Old 12-09-2009, 06:39 PM   #13
gpsoft
To check who's "keeping" file or folder, I'd recommend a Handle utility from former SysInternals team, that should be available now on Microsoft web site (google it please). This tool shows you all or specific open files and their holding processes and handles. And using this tool you can also forcefully close handles that are in use!
Old 12-09-2009, 10:18 PM   #14
I use Process Explorer, its a free download here.....
Process Explorer
Old 12-10-2009, 07:53 PM   #15
gpsoft
And check a whole bunch of other SysInternals utilities available at the link above!
