Old 11-25-2008, 01:49 AM   #1
metomeya
metomeya's Avatar
Need help displaying SQL databases
So I know the code to display a SQL database but....
I'm trying to figure out an easy to display different databases with the click of a button (so each button you press displays a different database replacing the old one).
I was thinking of using an iframe and java scripting to get the job done.
What exactly would the code be for this?
Old 10-12-2010, 04:56 AM   #2
Shweta
Re: Need help displaying SQL databases
Can you tell me that how we can implement inner and outer joins in SQL.
Old 08-27-2011, 01:14 PM   #3
middi
Many commands are used for it like the show tables SQL command is used to display all the tables in a MySQL .For commands go for the tutorials i always prefer it by searching in google when any problem comes.
