Old 12-28-2008, 12:57 PM   #1
Skyhawk
Is it possible to move a folder with one click?
Is it possible to move the files in one folder to another folder using a desktop icon with one click? I need to "move" the files so that the source folder is empty upon completion. I'm running WinXP Pro on a PC.
Hope someone can figure this out since I have to do it periodically and it's such a hassle to do it manually step-by-step. Thanks.
Skyhawk
Old 12-28-2008, 01:35 PM   #2
Gorganzola
Gorganzola's Avatar
Re: Is it possible to move a folder with one click?
If it is always the same source folder and the same destination folder then yes this can be done. It'd have to be a double click though, haha.
TTFN.
A. One.
You can
in public.
Old 12-28-2008, 01:42 PM   #3
Skyhawk
Yes, it will always be the same source and destination folders. Could you list the step-by-step procedure to do it?
Thanks,
Skyhawk
Old 12-30-2008, 02:30 AM   #4
Skyhawk
Anyone?
Old 12-30-2008, 02:57 AM   #5
Valium
Gotta hav'em :D
Valium's Avatar
Well easiest way I think would be to write a batch file, google for it, you should be able to make it work on your own, it's pretty easy. And to be honest, it'll teach you something and might help you out in the future instead of just copying what somebody else made for you.
Greetz
Old 12-30-2008, 09:23 AM   #6
DBoone
Just call me Dave
DBoone's Avatar
I agree. Shouldn't be too hard. If you can't make it work let us know and I'm sure someone will help you out.
Water cooled rig - Obsidian 800D, Corsair HX750, Sapphire 5570, Asus Rampage III Extreme, Intel Core I7-930, 6GB Corsair Dominator PC3-12800 (DDR3 1600) memory, Windows 7 Pro
Old 12-30-2008, 02:18 PM   #7
Skyhawk
Greetz
Hi Greetz,
I had already tried that but could not get the DOS move cmd to work just running it from the cmd line. I created two test folders on my data drive h: named test1 and test2. I copied 3 files into folder test1. Here's the command I used:
c:\Documents and Settings\Dad>move h:\test1\*.* h:\test2
Dos would just move the cursor down two lines and redisplay the prompt "c:\Documents and Settings\Dad>" without doing anything. When I opened the two test folders, the 3 files were still in folder "test1" and folder "test2" was still empty. I tried various things for about 10 minutes and it wouldn't work so I posted my question.
I couldn't figure out what I was doing wrong,
Skyhawk
Old 12-30-2008, 03:20 PM   #8
DBoone
Just call me Dave
DBoone's Avatar
MS-DOS move command help
Check out that link.
Old 12-30-2008, 03:22 PM   #9
Skyhawk
Hi Greetz,
Skyhawk
Well I'll be darned. I powered off for the night and rebooted this morning. The move command above worked. I was able to create a desktop shortcut and move the files. (FWIW, I've been having problems getting icons to appear in the system tray by the clock also. My WinXP Pro seems to be flakey. But that's a subject for another thread if I can't figure it out.)
But now I've run into another problem. I'm having problems with long file names and file names that have a space in them. Here's what I'm trying to do:
I want to move the contents of:
C:\Documents and Settings\Dad\Desktop
-to-
C:\Documents and Settings\All Users\Desktop
I tried using the ~1 trick like "Docume~1" but can't figure out how to use the ~1 with "All Users".
Any help for this?
Thanks,
Skyhawk
Old 12-30-2008, 03:25 PM   #10
DBoone
Just call me Dave
DBoone's Avatar
Go to the site in link I posted. One of their faq sections deals with long file names.
Information about long file names
Last edited by DBoone; 12-30-2008 at 03:32 PM.. Reason: edited to add another link
Old 12-30-2008, 03:58 PM   #11
Skyhawk
Using the quotes on the long folder names worked. Got it all to work now and it does it with a single click...
Thanks!
Skyhawk
Old 02-05-2009, 07:20 AM   #12
khanshab
No, it is not possible
Old 02-05-2009, 02:35 PM   #13
Skyhawk
Already did it.
