Old 01-27-2009, 11:08 AM   #1
rjs735
Virus? What I am not sick
rjs735's Avatar
New to Virtualization on a PC
Doing some research on the question of virtualization on a PC.
Have come to these conclusions and with your help maybe I can validate some of them.
I have downloaded and installed and tried Virtual PC 2007 Sp1 and it appears easy to create a virtual image to run but no USB support except for file copy from the real system to the Virtual so that's a negative.
I also have copies of VMware player since it's free but can only run virtual image created by an other process like VPC.
Also have a copy of Virtualbox. Now to my question.
Is it safe to assume that in my scenario it would be a good idea for me to create my images with VPC2007 and run them under either Vmware or Virtual box. If so then which would be better choice.
I have agreat deal of knowledge in CP/67, CMS, Vm/370, MVS/370, MVS/390 ESA VM/ESA from both a system programmer and user perspective. All of these are virtual products or user environments. So the concept of virtualization is not new to me.
Optorite CDRW WD 40GB
All systems are networked
Old 01-27-2009, 12:22 PM   #2
Re: New to Virtualization on a PC
I just downloaded Virtualbox. Then installed XP on it, VirtualBox is kind of self explanatory. You can't really hurt anything by just jumping in....
Old 01-27-2009, 02:58 PM   #3
JBNimble
Renaissance Man
JBNimble's Avatar
I'm not certain if this is relevant to your needs:
I use Virtual PC 2007, and I can access a second physical hard drive (D: on my computer, called X: in Virtual PC).
I can copy either direction between the Virtual PC C: drive and X:. And I can copy via USB (outside of Virtual PC) to the D: drive. I'm almost certain this works while Virtual PC is running, although generally I access my D: after I've closed down Virtual PC.
I use Virtual PC to run W2000, because it's the last Windows that runs my irreplaceable DOS genealogy program. I backup my Virtual PC data from virtual C: to X: (really D). Then I can offload the data to a flash drive and put it on my laptop which still runs native W2000, or for backup to a CD.
Rome didn't fall in a day.
Old 01-27-2009, 03:24 PM   #4
I really like VirtualBox though I can't say I run it through its paces. Version 2.1 is clearly faster than 2.0 and I've used it for WinXP, OpenSolaris and Win7 on a Linux host.
I don't understand why you'd want to create the image using Virtual PC and not the tool you wish to use to actually run it.
Old 01-27-2009, 06:19 PM   #5
rjs735
rjs735's Avatar
The issue is one of cost. VPC 2007 is free but has a few negatives. VMware is free for the player but can't create any images with player you have to pay for the VMware desktop for creation.
I haven't looked at Virtual box in any detail as far as creating images to run.
Iguess what I am also hearing is to jump in and do. Which will undoubtedly create some more questions.
Thanks for the responses.
Old 01-27-2009, 06:48 PM   #6
rjs735
rjs735's Avatar
Just researched Virtualbox and I do believe it is the one I am going with. Also the fact that it seems ( Sir Skully and Kongo) are pro Virtualbox and viewing the snapshots of various images as well as the tools makes me believe it's the option to choose. I hate it when MS just goes half way and leaves the lifting to everyone else. Vis a Vi USB support. I guess maybe in VPC 2007 sp2???
Thanks. I just downloaded the docs and the x86 code. I'll keep you posted.
Old 01-27-2009, 07:03 PM   #7
Yeah after my own research, I concluded that VirtualBox was the one for me.
I think you'll be happy with VirtualBox, it lacks in some areas. But I believe its the best free VM.
Old 01-27-2009, 08:11 PM   #8
I like VBox, though VPC works well with M$ products (I run XP and Win2k8 server on VPC - Ubuntu 8.10 under VBox).
VMWare used to have a free (limited) server version - you just had to register. But, if you want DX9 and other fancy stuff, then you have to pay for VMWare Workstation.
Old 01-28-2009, 01:37 AM   #9
GWillakers
I just started to look at virtual PC 2007.
It never dawned on me that you could create your images on one product,
and run them in another.
I so far have been impressed with the ease of setting up and running VPC.
But like everything else...got to get your hands dirty...with the nuts and bolts..
