Old 04-04-2009, 09:38 AM   #1
Tbolt
Tbolt's Avatar
Nested looping in C - Im stuck
So I thought I had a pretty good understanding of looping even though I missed class the day it was taught. However now I am in a conceptual mind**** of how to approach this.
The assignment is to create a dynamic tic-tac-toe board using multidimensional arrays and functions (with array passing)
here is what the output should look like:
hxxp://i4.photobucket.com/albums/y108/phishkids11/toe1.jpg
here is what I have so far, focusing on the display board part
Code:
// INCLUDES
#include <stdio.h>
// DEFINES
#ifndef __TRUE_FALSE__
#define __TRUE_FALSE__
#define TRUE 1
#define FALSE 0
#endif
// ROWS and COLS
#define ROWS 7
#define COLS 7
#define MARKONE 'X'
#define MARKTWO 'O'
#define BLANK   ' '
// PROTOTYPES
void InitializeBoard(char[ROWS][COLS]);
void DisplayBoard(char[ROWS][COLS]);
int PlayerMove(int, int, char[ROWS][COLS], char);
// MAIN
int main() {
	// declare variables
	char board[ROWS][COLS];
	// initialize board
	InitializeBoard(board);
	// populate the board with moves
	PlayerMove(1, 1, board, MARKONE);
	PlayerMove(1, 2, board, MARKONE);
	PlayerMove(4, 3, board, MARKONE);
	PlayerMove(1, 1, board, MARKTWO);
	PlayerMove(6, 2, board, MARKTWO);
	PlayerMove(4, 12, board, MARKTWO);
	// display the board
	DisplayBoard(board);
	// exit program
	return 0;
// FUNCTION IMPLEMENTATIONS
void InitializeBoard(char board[ROWS][COLS]) {
	int i = 0, j = 0;
	for(i = 0; i < ROWS; i++) {
		for(j = 0; j < COLS; j++) {
			board[i][j] = BLANK;
void DisplayBoard(char board[ROWS][COLS]) {
	int i = 0, j = 0, k = 0;
	printf("**************TIC-TAC-TOE**************\n\n");
	for(i = 1; i <= COLS; i++) {
		printf("%2d", i);
		printf("\n\n");
int PlayerMove(int row, int col, char board[ROWS][COLS], char symbol) {
I feel like I am trying to approach this from the wrong angle, and because of that I can't comprehend how to do it. I imagine I will need to nest a loop within a loop within another loop.
Any advice would be great, not necessarily with this particular problem but anything with looping that would help me understand it better would be great.
Old 04-04-2009, 03:41 PM   #2
Re: Nested looping in C - Im stuck
For your DisplayBoard() function, just do it the same way you did the InitializeBoard() function. Just replace 'board[i][j] = BLANK' with the appropriate print function.
Good luck!
Old 04-04-2009, 05:48 PM   #3
Tbolt
Tbolt's Avatar
Alright, I am starting to get it. I just had to go back to the basics and play around a bit before tackling this.
Thanks though =p
Old 04-04-2009, 08:03 PM   #4
just on this "developers block" syndrome you seemed to be experiencing... I'm a big fan of design... ie: conceptualising the solution via a process of design which then gives you a skeletal structure in which to hang your code.
I tend to use "structure" charts for this... and use cases of course... and activity diagrams or even sequence diagrams...
I know this may be a trivial example for some ppl... coding top down has advantages (eg: speed) if you are very familiar and experienced with the solution domain... but otherwise... design!
