Old 08-18-2009, 01:44 PM   #1
JBNimble
Renaissance Man
JBNimble's Avatar
Internet Slowdown
After an hour or two, my Internet response frequently approaches nonexistent. Rebooting corrects the problem.
System:
Verizon FIOS (Fiber Optics)
Core 2 Duo 2.4 GHz
Intel D975XBX2
2GB Corsair Dominator RAM
XP Pro, Service Pack 3
Norton 360 -- latest version, updated continually
CCleaner -- used frequently
System Mechanic 7 -- used frequently
Spybot -- updated and used frequently
Ad-Aware Anniversary -- updated and used frequently
Prime suspects:
Malware undiscovered by all that security software
RAM filling up
Any ideas of the problem of a fix?
How do I check for free RAM? And if it's low, how do I clear it?
Thanks,
Jack
Rome didn't fall in a day.
Old 08-18-2009, 02:20 PM   #2
Re: Internet Slowdown
Have you tried speedtest?
Speedtest.net - The Global Broadband Speed Test
Norton would be my first suspect.....
Here's a link to a guy who had a problem with Norton
Norton 360 - Slowing down PC - Windows
ROG RAMPAGE VI APEX
i9-7900X... EK water cooled
SAMSUNG PRO 960 1tb M.2
Ducky keyboard
Old 08-18-2009, 02:26 PM   #3
What browser are you using? I believe that some of the older Netscape/Mozilla/Firefox browsers were known for having "memory leaks."
You can check how much RAM is being used under the Windows Task Manager (hit the "control-alt-delete" keys at the same time), and under that the Performance tab. It might be a good idea to post a screen-shot of that, if any of what it says is not clear to you.
Also, when the symptoms arise look under the Processes tab to see if some process is shown as having a high cpu utilization percentage.
And I second Skully's suggestion that the Norton software be included among the possible suspects.
Old 08-18-2009, 02:31 PM   #4
JBNimble
Renaissance Man
JBNimble's Avatar
Thanks,
Just tried Speedtest:
Download: 4.95 Mb/sec
Upload: 1.82 Mb/sec
I'm using Internet Explorer 7.
More than half of my RAM is free.
This after 45 minutes online, with no slowdown symptoms evident.
I'll have to try this when I'm having problems (which, of course, won't reappear when I want them to).
Old 08-18-2009, 02:36 PM   #5
Originally Posted by JBNimble View Post
Thanks,
Upload: 1.82 Mb/sec
You're welcome.....Hope ya find your problem.....
ROG RAMPAGE VI APEX
Ducky keyboard
Old 08-18-2009, 02:38 PM   #6
Also try Speakeasy's speed test, selecting the location that is nearest to yours. 5mbps download speed is certainly fast enough to be satisfactory for typical internet usage (other than transferring large files), but is much slower than I would expect from FIOS. But delays in the internet pathways between your location and the speedtest.net server could be limiting the measurement you get from them.
Speakeasy - Speed Test
Old 08-18-2009, 03:03 PM   #7
JBNimble
Renaissance Man
JBNimble's Avatar
ctal,
As I recall, FIOS has a 5MB/sec and a 15MB/sec service.
I chose the slower, cheaper speed.
Old 08-18-2009, 03:23 PM   #8
Well, I guess it's evolving, and location-dependent. Their website currently shows 15 down/5 up as the lowest price plan:
Verizon | FiOS Internet: Plans
Old 05-03-2011, 01:50 PM   #9
sansam
If you need to increase your speed means just try to clear cookies and reset your modem and check cable connections again if you have any problem after that means just try to make speed test on here by use this ip-details site after that you can conclude whats your error ..then you can contact the service provider....
Old 12-21-2011, 06:31 AM   #10
apjhone
Hi, To boost internet speed you can try
1) Clear History using cc cleaner.
2) delete cookies, go to start>run>cookies
3) delete temp files, start?run>temp or %temp%.
4) go to my computer and c>properties>DiskCleanup.
If you don't have internet problem then this will certain help
Old 04-09-2014, 11:33 PM   #11
Md Selim Uddin
@sansam I agree with your comment.
Old 04-11-2014, 07:26 AM   #12
barney_jeks
Sometimes the reason of low Internet speed are viruses. Did you check your computer for them?
