Old 09-29-2009, 08:29 AM   #1
Morgromir
Internet is down
Hey i got a problem and this seemed like the best place to fix it. My computer does not have internet.
It has a router and a modem and it says that the internet is connected to the computer but for some reason i cannot connect. My router broadcasts internet to my moms labtop and my xbox live works fine i just cant figure out why this happened.
Any suggestions?
Old 09-29-2009, 02:26 PM   #2
Brian
Brian's Avatar
Re: Internet is down
Then how did you make this post???
Sorry, just a little "Welcome To The Forum" humor. Thanks for playing along.
Anyway, is your internet connection to your router hard-wired or wireless? If hard-wired, have you checked the cables to make sure everything is plugged in firmly and in the right place? If your connection is wireless have you tried a hard-wire connection? Also, have you tried disconnecting your PC from the router entirely and connecting your computer directly to the modem?
Old 09-29-2009, 05:02 PM   #3
Belgareon
Belgareon's Avatar
Was thinking the eaxct same thing!
Have you tried restarting router + modem? If this doesn't work, try changing the router port your computer is connected to to another one (this if you have another one available). Also, has anything changed in your computer lately? Installed any new network devices, drivers or such?
Good luck!
Intel Core 2 Duo E6600 2.4GHz Socket LGA775 4MB
Scythe Ninja PLUS Rev. B
Corsair Powersupply 520W, 120mm Fan
Corsair XMS2-6400 TWIN2X2048-6400 4 GB.
Asus Extreme Radeon X1950Pro 256MB
Asus P5W DH Deluxe
Antec Case Performance One P180B SILVER
NEC DVD_RW ND-3502A BLACK
Old 10-05-2009, 12:59 PM   #4
Morgromir
Ha im at school
thanks by the way it works now
Old 03-27-2010, 02:14 AM   #5
radha
thks for rising this query . i am also faceing this problem and was breaking my head.
lara
Old 03-27-2010, 02:14 AM   #6
radha
Good luck!
thnks for simple solution
lara
Old 10-18-2010, 01:46 AM   #7
Shweta
Really helpful for all internet users...
_____________________________________
