Old 09-30-2009, 04:08 PM   #1
JimTram
Seabees, USN (Retired)
JimTram's Avatar
32bit or 64bit
Can anyone tell me if there are tangible performance differences between the two versions. I do understand the ability to use over 4G DDR. Anything additional.
So if I go from XPPro 32bit to Win7 - what do I see/feel?
Thanks all
CyberPower CP1350PFCLCD
Sennheiser HD280 Pro
Win10 Pro 1703
Old 09-30-2009, 04:13 PM   #2
polonyc2
Legacy
polonyc2's Avatar
why would anyone even want to remain at 32-bit these days?...if given the option (and the retail version of W7 comes with both versions one 1 disc) why would anyone choose not to go 64-bit?...even if there were 0 differences I would go with 64-bit
plus more and more software is being released in 64-bit format...Office 2010 will come in a 64-bit version, Flash, Quicktime are coming soon, games are crawling over there etc...the real question should be what does 32-bit give you over 64-bit?
Intel i7 980X (Gulftown)
***** Noctua NH-U12P SE2
G.Skill Falcon I 256GB SSD
Lian Li PC-A70B (black)
***** Corsair HX850W
Lite-On IHAS424
***** NEC 2490WUXi LCD
Windows 10 Home 64-bit *****
Old 09-30-2009, 04:54 PM   #3
JimTram
JimTram's Avatar
Re: 32bit or 64bit
Peoples like me who skipped Vista and only have XPPro 32-bit.
OK - I understand 64-bit is the future, and I do plan to go that route when Win7 is released. I would just like to know what I will see/feel as I do so?
this was interesting:
Windows 7 Performance Tests - PC World
Win10 Pro 1703
Old 10-01-2009, 02:12 PM   #4
Belgareon
Belgareon's Avatar
Re: 32bit or 64bit
Thanks all
Main differences are:
1.Some older PC application will only work in a 32-bit OS. Some programs are today only available in 32-bit version although software companies will probably have to offer 64-bit solutions soon(if not already) to keep up with the competition and demand. Most of the software people use in general is already 64-bit compatible today (they are released in 64-bit versions).
2.You should at least have 4 gigs of RAM installed on your computer, if you have less than 4gig, your system might actually become slower rather than faster when switching over to 64-bit.
3.If you have more than 4 gigs of RAM on your OS will be able to work faster and support more RAM then the standard 32-bit OS does (4GB).
4. Your computer and CPU must have 64-bit support in order for a 64-bit OS to work properly.
5. If you want to upgrade your current 32-bit OS to a 64-bit you can not use the "upgrade"-option, you must make a new clean install.
This is sorta a summary on the info I've read.
Good luck!
Intel Core 2 Duo E6600 2.4GHz Socket LGA775 4MB
Scythe Ninja PLUS Rev. B
Corsair Powersupply 520W, 120mm Fan
Corsair XMS2-6400 TWIN2X2048-6400 4 GB.
Asus Extreme Radeon X1950Pro 256MB
Asus P5W DH Deluxe
Antec Case Performance One P180B SILVER
NEC DVD_RW ND-3502A BLACK
Old 10-01-2009, 04:01 PM   #5
JimTram
JimTram's Avatar
Re: 32bit or 64bit
Thanks for taking the time. I meet the 4G requirement and my cpu has 64-bit support. I'll just install the 64-bit when I move over to Win7. Looking fwd to it.
Thanks again
Good luck!
Win10 Pro 1703
Old 10-06-2009, 03:17 AM   #6
Anarchi
Anarchi's Avatar
Re: 32bit or 64bit
I went from XP 32bit to Win7 64bit.
I dont notice a performance difference, but then again, I have not compared benchmarks in video/music encoding (which is where you really see a difference).
As for the problems
- some 32bit apps dont run properly in 64bit Windows. For example 7zip doesnt add the context menu's in explorer, but all you need to do is instsall the 64bit version of 7zip.
- Many games and patches dont install properly. I have need to move their registry settings from Wow6432Node back to their original (proper) location.
- Some old 32bit apps that ran great in XP simply dont work properly. Unfortunately there are no 64bit versions available.
- I had to change a BIOS setting (memory remapping feature) to access the full 4GB of RAM.
Ive had no problems with drivers though (lucky I dont have an old printer or scanner )
...so be wary that 64bit is not quite ready yet. Stick to 32bit if you want the best compatibility and you don't care about an extra ~50% performance when encoding media.
Mobo: Asus P5B Deluxe
CPU: Core 2 Duo E6750
Memory: 4GB DDR800
Video: GeForce 260GTX 896MB
OS: Windows 7 Pro 64bit RTM (and XP Pro)
Sound: Auzentech Prelude X-Fi
Old 10-06-2009, 03:33 AM   #7
JimTram
JimTram's Avatar
Re: 32bit or 64bit
Wow - this is quite encouraging! No notice of performance increase?
What games and apps did you have trouble with?
As for the problems
Win10 Pro 1703
Old 10-06-2009, 03:48 AM   #8
Anarchi
Anarchi's Avatar
Re: 32bit or 64bit
I dont notice any performance difference. But I'm sure a MPEG4 H.264 video encode would be considerably quicker which I have yet to try.
Bioshock patch simply fails to work no matter what I tried.
FarCry2 failed to write its own registry settings.
A FarCry 2 addon failed to install. I had to boot into XP, apply the addon, then copy the reg settings back into Win7.
Grid failed to detect my Logitech Steering wheel (stuck in reverse).
Memory: 4GB DDR800
Old 10-06-2009, 04:15 AM   #9
Re: 32bit or 64bit
...Bioshock patch simply fails to work no matter what I tried.
A FarCry 2 addon failed to install. I had to boot into XP, apply the addon, then copy the reg settings back into Win7...
I've been running Vista 64bit for a while now and installed those games before... with no problems. I wonder if its some kind of Win7 issue?
Old 10-06-2009, 04:19 AM   #10
JimTram
JimTram's Avatar
Re: 32bit or 64bit
Great my favorite game! Thanks.
Win10 Pro 1703
Old 10-06-2009, 03:07 PM   #11
JimTram
JimTram's Avatar
Re: 32bit or 64bit
Whereas my current mobo has only 4Gig RAM - I may just install W7 in 32-bit. I have no software written for 64-bit.
Seem to be a lot of hype and no substance per performance gains. The English alphabet has not changed, so Office 2007 is fast enough.
Next board upgrade I'll checkout 64bit.
Win10 Pro 1703
Old 10-07-2009, 01:52 AM   #12
Anarchi
Anarchi's Avatar
Re: 32bit or 64bit
@Jim, If you install 32bit Windows, you will only be able to access about 3GB of RAM. So depending on what apps you run, you may want that extra 1GB.
Some games use a huge amount of RAM (for example C&C Tiberium uses 1.5GB+ on large maps), plus you have the OS and Antivirus, and all the other bits and pieces - it all adds up.
But most games should be happy with 3GB RAM in 32bit. (until the new Rage game by id software comes along hehe)
@zapionics, hmm maybe it is a Win7 64bit problem. I've never installed Vista 64bit so I wouldnt know.
Memory: 4GB DDR800
Old 10-07-2009, 02:03 AM   #13
I heard that if one bought a copy of Vista right now, since the release of win7 is less than 30 days away, that one would get a free upgrade to win7.
Is it true? Does anyone know for sure? And if it is true, is it so with ALL versions of Vista?
Asus X48 Rampage Formula / Intel Q9450 2.66 @ 3.2 / 2 x 2GB OCZ Reaper HPC PC2 8500 /
Asus Radeon HD4870X2 Tri-Fan 2GB graphics card / 24" DeLL Ultrasharp 2408WFP monitor /
Western Digital Raptor X Hard Drive / Two Western Digital Caviar RE2 WD5001ABYS 500GB 7200 RPM SATA 3.0Gb/s Hard Drives /
Creative SoundBlaster X-Fi Elite Pro 7.1 / Creative Gigaworks S750 7.1 Speaker System /
Lian Li 343B cube case / PC Power & Cooling Silencer 750 Crossfire Edition /
IOGEAR GCS1782 GCS1782 Dual-Link DVI KVMP switch with 7.1 audio
Old 10-07-2009, 02:56 AM   #14
polonyc2
Legacy
polonyc2's Avatar
survey says---> True
https://om2.one.microsoft.com/opa/Va...caleCode=en-us
** does not apply to Vista Basic
don't know if you get the full version of W7 or just the upgrade version
Lite-On IHAS424
Old 10-07-2009, 04:41 AM   #15
JimTram
JimTram's Avatar
Re: 32bit or 64bit
It's only an interim measure as I get familiar with the new OS. I don't want to spend the bucks on more than 4G RAM for my current board. Next build will have 8G and at that point I will install 64Bit.
My concern is gaming and I want to be sure Win 7 is compatible with:
Far Cry2
Crysis
Crysis Warhead
STALKER Franchise
Doom3
32Bit is probaly more friendly.
Win10 Pro 1703
