Old 03-01-2001, 06:25 PM   #1
freddy13
Unhappy
i have SB live value and when the pc starts it pops and then every so often it does it again. It happens infrequently, not enough to make me rip my hair out, but it is strange.
The man in black fled into the desert and the gunslinger followed.
Old 03-02-2001, 08:56 AM   #2
DrSilver
What motherboard do you have?May be it`s the installation of electricity which is not clean.
I have a sblive and i get it sometimes too
Old 03-02-2001, 09:38 PM   #3
freddy13
mine is without onboard audio... how do i tell exactly what model i have?
Old 03-07-2001, 03:49 AM   #4
DrSilver
Lightbulb
I don`t think it`s the mainboard b/c I tried my sb live sound card with both the gigabyte ga-6vx7b-4x (via 694x &686B chipset) and asus cusl2-c and both gave some "popping" at times.I sure it`s the electricity coming through the wall socket.I suggest you try your computer in a different wall socket.
Old 03-07-2001, 03:18 PM   #5
LongJohn
I get the same but it is not loud!
The cause of my pops is my "Frig".
When the compressor turns ON, the speakers pop.
Enjoy,
LongJohn
Old 03-08-2001, 02:07 AM   #6
Guntro
I got just the same pops with my SB Live! 5.1 because of the same reason, the compressor of my fridge. It's not loud but sometomes late at night when it's quiet, it pops that loud that it scares the hell out of me
I tried to move the plugs around but it affects the whole power grid. I live with it because it happens only once in a while.
Old 03-10-2001, 04:10 AM   #7
DaveM
Whats in a title, anyhow?
DaveM's Avatar
Set all your volume sliders in the mixer, including the master output to 75%.
Then turn up the volume on your speakers.
Don't take your mixer settings above 75%.
Except Digital CD Audio or Digital Spdif Audio inputs, they should be set to 100%
Old 03-12-2001, 03:03 PM   #8
freddy13
Question Why? Dave?
Why do we have to do that?
curious br0therfrank
Old 03-12-2001, 03:51 PM   #9
DaveM
DaveM's Avatar
I have found that the the line output of the soundblaster live is overdriving (clipping) my amplified speakers when levels are set above 75%.
Also When levels are at 75% that is what is termed in the audio industry as "Unity Gain" or "0dB gain".
So anything above 75% may cause your amplifier to "Pop" (also known as clipping) on peak signals.
My speakers are the Altec lancing ACS54, 4 channel with subwoofer.
Some Amplifiers require a -4dB input, Some Amps requires a 0dB input and some require +10dB input.
If you send +10dB to a device rated for -4dB input you're going to have a lot of clipping and popping.
[Edited by DaveM on 03-12-2001 at 09:51 PM]
Old 03-17-2001, 04:22 PM   #10
topazal
Lightbulb
If in fact the popping and static sounds are the result of power line problems you may need to put a good surge protector and a UPS unit infront of your system to filter and condition your power supply.
I live in a remote country area with a lot of electrical problems and I have both inline surge protector's and TrippLite UBS's in front of my system's and have had no such problems with my SB live cards (3) in my home.
Just a thought.
Good Luck!
[Edited by topazal on 03-17-2001 at 05:29 PM]
Old 11-19-2008, 01:59 PM   #11
Randalles
Re: my speakers "pop" every once in a while?
Hi all, I'm new to this group and am having a similar problem but it doesn't seem related to the volume levels or noise from external devices. My problem has to do with the speakers poping while browsing from page to page using IE. I'm running XP on an Asus M2N-MX SE Plus mobo using the onboard Realtek HD audio connected to some old Boston SPDIF speakers. The audio manager is configured for digital, as it should be, I've reloaded my codecs files, upgraded the BIOS and still cannot figure out what is going on. It's like the sound system is switching between different modes or going to sleep after a few seconds when it pops. However, if I play something (music) with Windows Media Player from my HD then pause the playback, I can browse all I want with no poping and the system sounds, like browser clicks etc., play as normal. Without runing WMP I'm backing to the poping. Any suggestions would be appreciated. Thanks.
Old 11-19-2008, 03:56 PM   #12
Slyder
all wet
Slyder's Avatar
Very good tip. I found this out long ago, but never knew the reason why it worked.
Slyder
HP dv9035nr Specs: 1.66 core 2 duo , 160GB (80GB x2) 5400rpm, 2gb 667 ram, GeForce Go 7600 256 dedicated, 17 in screen
Old 11-20-2008, 01:05 AM   #13
Deer Slayer
Unscanable!!! Tatoo???
Deer Slayer's Avatar
Arrow Re: my speakers "pop" every once in a while?
Your popping noise could be not even comming in on the audio line. I agree, you need a power conditioning UPS, or similar device. The pop could be due to a large motor, or another device that draws a lot of current causing surges in the line. More than likely it's a motor, because they can backfeed surges into your household power. See if it coincides with the AC/heat, or fridge, or sump pump (like mine was doing). You'll probably find the speakers do it whether plugged into the computer or not. The pop is power from the mainboard initializing the card when your machine starts. I dunno what to tell you with that. I leave my volume at about 85% and I use the volume control on the speakers.
Old 11-20-2008, 06:31 AM   #14
jaketerminate
Maximum Post
jaketerminate's Avatar
I have this same incident happening to me, with the whole popping of the speakers at initial startup. I think this is directly related to an external sound card I have them hooked up to them (M-Audio Fast Track USB) that is USB powered. I think the instant start of the sound card registering with the speaker line and the system start causes the big pop your speaking about. Like Deer Slayer was saying you might need something to regulate the power on cycle of your speakers, but in my case I have my USB Card unplugged on boot and I plug it back in after everything is up and running.
"Mozart" Rig #1
Case: Thermaltake Mozart TX
Mobo: Asus P5N-E
CPU: Intel Core 2 Quad Q6600 2.4ghz
Memory: 4GB (2x 2GB) G.Skill DDR2
Hard Drive: 320 GB Western Digital 7200 RPM
Video Card: EVGA Nvidia 9800GX2 1GB (512MB per GPU)
Power Supply: 600W OCZ StealthXStream
OS: Windows XP Homee Edition and Ubuntu Linux x64
Monitor: 22" Westinghouse LCD and 2 Dell CRTs
HP G60t
CPU: Intel Pentium 2.0ghz
Memory: 4GB
Hard Drive: 250GB 5400RPM
GPU: Intel Graphics Media Accelerator 4500M
OS: Windows 7 Ultimate Build 7000 Beta + Ubuntu Linux
HP Pavillion tx 2000z Tablet
CPU: AMD Turion x2 2.1Ghz
Memory: 3GB
GPU: ATI Radeon 3200 64mb
1TB Seagate External Backup Drive
Old 12-18-2009, 10:27 AM   #15
scenariotime
The pop sound can happen for a number of reasons, up to and including the performance of the card itself and the hardware on the system it is connected to. Buffering problems can cause pops. Electrical spikes can cause pops. Not having enough system resources can cause skipping and/or pops. Speakers can also pop if they are not good quality. It all depends. Do some testing to find out what is really causing it.
