Old 01-23-2009, 09:09 AM   #1
emmaelle
Junior Member
Fix error Windows can't find explorer.exe
Troubleshooting Steps
press Ctrl + Shift + Esc
then file new task, type regedit
then go to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Image Execution Options\
in this list there will be a entry explorer.exe right click on it and export it. then on the right hand side delete the "debugger" key.
Becareful regedit is dangerious if you aren't paying attention, always backup keys before you play with them.
2- Run Once
Create a .reg file or edit it directly.
CAUTION: Before making any changes to the Windows XP Registry, please backup your Windows XP
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"RunOnceHasShown"=dword:00000001
"RunOnceComplete"=dword:00000001
I am an online technical support specialist for iYogi's
wing, a leading IT support company Headquartered in India.
Providing an Annual Unlimited subscription to technical support for best and reliable charges, The company employs 600
professionals servicing customers in the US, UK, Canada, Australia and Singapore. It has also been declared a winner of the Red Herring 100 Award
Old 05-29-2009, 03:49 AM   #3
sneakersupplier
Guest
Posts: n/a
Smile ver best president obama
it is very president obama man
