Old 12-05-2009, 11:46 AM   #1
wonderwrench
wonderwrench's Avatar
TweakHound's Windows7 Install Guide
Our old friend has been busy! Guide
Old 12-05-2009, 12:16 PM   #2
Re: TweakHound's Windows7 Install Guide
Thanks.....its gooden.....
Yeah miss seeing tweakhound around...
Old 12-05-2009, 04:09 PM   #3
Thumbs up Re: TweakHound's Windows7 Install Guide
Thanks Tweakhound great write up, hope he comes around again!
Old 01-11-2010, 09:05 AM   #4
Bofinn
I'm gettin' dizzy!
Bofinn's Avatar
The page loads all funky for me. Can someone else try it?
---------- JimBo -----------
When in doubt, smack it!
Old 01-11-2010, 09:55 AM   #5
Hey bud, mine loads fine........
Old 01-11-2010, 12:50 PM   #6
rjs735
Virus? What I am not sick
rjs735's Avatar
Bofinn are you by any chance using Opera?? If you are as I am (10.5 with unite) then just some links show up. It apparently is formated for IE or Firefox. I used firefox to access it and everything is there. I know it is extra effort to format for other browsers than IE. SO I've gotten used to swapping browsers when I don't see data or downlaod links.
Optorite CDRW WD 40GB
All systems are networked
Old 01-11-2010, 12:53 PM   #7
I'm using Opera 10.5 and it comes up ok for me.....
Old 01-11-2010, 01:06 PM   #8
rjs735
rjs735's Avatar
When I go to tweakhounds site his blog comes up fine but not the windows & guide. I just checked and I am using 10.1 and the win7 guide doesn't show up. I opened 10.5 and the win7 guide is there. Sorry. I don't use 10.5 regularly because it doesn't have the e-mail client as yet. It's only an alpha release.
Thanks Skully
Old 01-11-2010, 02:05 PM   #9
Thanks Skully
Oop's I was mistaken its opera 10.10 that I'm running.....
Old 01-11-2010, 03:04 PM   #10
rjs735
rjs735's Avatar
In opera 10.1 mine was set to author mode for viewing by default when I reset it to user mode I see the document but not the same formating that I see in Opera 10.5A in default which is author mode.
I guess that's why new versions come out.
Old 01-12-2010, 07:33 AM   #11
mcmd
mcmd's Avatar
Bookmarked for when I make the switch to W7. Mucho thanks to Wonderwrench for the OP.
I'm just the loyal opposition.
Old 01-12-2010, 12:51 PM   #12
wonderwrench
I wish I had this info when I installed 7 originally as I would have been much more confident.
Old 01-16-2010, 12:57 PM   #13
Sylar
Sylar's Avatar
Stickying this.
