Old 01-21-2010, 03:39 PM   #1
Drufuss
Drufuss's Avatar
openSuse 11.2 installation problems
Hi there!
Besides from the looks of this forum section (desert? no one there, no one posting, maybe some occasional tumble weed passing by) i'm asking for help on installing the latest opensuse (11.2) on my rig.
everything looks fine until i come to paritioning my hard drives. Somehwo my intel raid0 doesn't seem to be correctly seen by opensuse.
I have two 1TB disks (WD green) in intel raid0 on my rig. These 2TB are divided into 4 paritions.
1 partition is 60 GB (system)
2 partition is 800 GB (videos)
3 partition is 400 GB (data, programs, games)
4 partition is 250 GB (user data, music)
the 4th partitions is part of an extended partition, within this partition there are over 350GB left for linux to use.
Somehow the suse partitiones doesn't want to recognize partition 4 as NTFS, therefore won't let me mount it. It calls this partition partition6, same as the linux boot partition it wants to build.
Tried to create the partitions i need with partitoin manager in windows andf then install linux, but then the suse-partitioner sees my partitions but show some akward start and end cylinders for them.
So i don't dare going any further because i'm afraid existing windows partitions may be destroyed.
Anyone out there who has installed 11.2 on an intel raid 0 system (anyone out there at all?)?
Greetings
Dru
System specs:
Asus Maximus VI Formula (watercooled)
Core i7-4790K 4.00 GHz (watercooled)
4 x 8GB DDR3-Ram PC3-2400 Kingston Beast XMP
3 x Samsung 840 EvoO 1 TB
Gigabyte GeForce GTX970 G1 Gaming (watercooled)
Soundblaster ZxR, Hauppauge HVR4400 DVB-T/S2, Logitech Z-5450 5.1 THX Wireless
Logitech DiNovo MediaDesktop 2.0
Enermax Platimax 750W
Pump: Laing DDC2
Radiator: Watercool Mo-Ra 3 420
Case: Cooltek Antiphon
Windows 7 Ultimate 64bit retail
CUSL2-C ruled! ..äh... RulEd!
Time flies like an arrow,
fruit flies like a banana.
Old 01-21-2010, 03:59 PM   #2
Re: openSuse 11.2 installation problems
Hi Dru,
By any chance do you have any flash card readers installed? If so, try disconnecting them before you do the install. I have no experience with openSuse, but I've used Ubuntu and found that it gets drive references all confused if there is a card reader present while it is being installed, and also during kernel updates.
Best regards,
Old 01-21-2010, 04:10 PM   #3
Drufuss
Drufuss's Avatar
Hi ctal!
Thanks for the quick reply, but there's no card reader or anything similiar installed here. Only what you can see in the sig.
At first i was tempted to install opensuse 11.2 without recognizing my 4th partition, maybe i could mount that later, but than i saw that the installer refers to it as partition 5 and partition 6. Also refers to the boot partition as partition 6. Very confusing.
Greetings
Dru
System specs:
Pump: Laing DDC2
