Old 01-29-2010, 12:43 AM   #1
pankajjha26
desktop windows manager stopped working
i got the msg "desktop windows manager stopped working working and was closed"..Also twice it got an abnormal shutdown...
then i worked today .as soon as i started the laptop
error msg of desktop window manager..
i m using win Genuine Windows(R) 7 Home Premium 64bit (English)
please suggest how to fix this
pankaj Jha
Old 01-29-2010, 08:51 AM   #2
If something like that happened to me, I would re-install a former working backup ghost image.
Do you have a backup? Or good restore?
Asus X48 Rampage Formula / Intel Q9450 2.66 @ 3.2 / 2 x 2GB OCZ Reaper HPC PC2 8500 /
Asus Radeon HD4870X2 Tri-Fan 2GB graphics card / 24" DeLL Ultrasharp 2408WFP monitor /
Western Digital Raptor X Hard Drive / Two Western Digital Caviar RE2 WD5001ABYS 500GB 7200 RPM SATA 3.0Gb/s Hard Drives /
Creative SoundBlaster X-Fi Elite Pro 7.1 / Creative Gigaworks S750 7.1 Speaker System /
Lian Li 343B cube case / PC Power & Cooling Silencer 750 Crossfire Edition /
IOGEAR GCS1782 GCS1782 Dual-Link DVI KVMP switch with 7.1 audio
Old 11-14-2011, 04:35 AM   #3
roncalion
Re: desktop windows manager stopped working
The first thing is make sure you do not have spyware and viruses. You must restart your PC and enter Safe Mode. After you scan your PC with these programs:
1 / Adware.
2 / Antivirus (Avast, Avira, Norton, etc.)..
3 / Check it out also the Regclearner.
Good luck.
