Old 03-07-2010, 11:03 PM   #1
jamesstevn
Post How to recover my Windows XP administrator password
Problem:
Have you forgot the administrator’s password? Can’t figure out your password and you can’t access Windows XP? That’s really so annoyed, right?
Solution:
Don’t worry, one of Windows Password Recovery Tool 3.0 highly recommended functions – Password Genius – can relieve you from such troubles. “Password Genius” tool is capable of changing and cleaning up the login password of Windows system. It can be used when users forgot login password and can’t access Windows system. It supports Windows XP, VISTA and Windows 7. You can recover any passwords, including Administrator and any User account password.
If you have lost Windows login password, all you need to do is to boot from password recovery CD. With only a few clicks, you can easily blank Windows XP administrator’s password.
Procedure of finding back Windows XP administrator’s password:
1. Boot from the CD.
2. Enter Gui interface, follow these steps: then you will have the interface looking just like the following picture.
3. Select the “Windows ” and “user account”, and then click “Start” , you’ll see:
4. Click “OK” and wait for a few seconds ,you’ll see “Password reset successfully” . Then you can access Windows without password. And you can reset your login password, too.
Check out the following link for a full tool review to see what other repair tools are included in this awesome CD.
