Old 05-21-2010, 09:48 PM   #1
CarlPo
Leatherneck
CarlPo's Avatar
Move O/S Partition To New Drive
Hello Everybody.
I broke down and ordered an Intel SSD today from Newegg. I presently have a Raid0 setup which is split into 2 partitions. Win 7 is installed on the C partition. I would like to clone only that partition to my SSD. Can anybody recommend a process and the software needed to do this.
Thank You.
Asus P6X58D Premium
I7 980X@4.0
CORSAIR DOMINATOR 12GB DDR3 1600 (PC3 12800)
PNY VCQ4000-PB Quadro 4000
Prolimatech Supermega CPU Cooler
CORSAIR Professional Series AX850 850W
LIAN LI PC-8FIR ATX Mid Tower Computer Case
Crucial RealSSD C300 128 GB
Western Digital VelociRaptor WD6000HLHX 600GB
Western Digital RE4 WD2003FYYS 2TB
PIONEER BD-RW BDR-206 Burner
Windows 7 64Bit
Old 05-21-2010, 11:28 PM   #2
wonderwrench
wonderwrench's Avatar
Re: Move O/S Partition To New Drive
I wish your question had an easy answer but it does not. There are several variables that may make migrating your existing Windows install to an SSD problematic. Boot problems and or poor performance with your SSD.
Please read these posts.
http://www.abxzone.com/forums/f154/s...ml#post1475976
http://www.abxzone.com/forums/f155/i...ig-120145.html
Old 09-13-2010, 02:19 PM   #3
rickyjohn12
I haven't tested this one. In general it's not a good idea to move programs from /Applications elsewhere, especially the Apple installed programs. You can do this by creating symbolic links, but if you miss anything, Software Update may break moved applications. Many third party apps can be placed elsewhere, and if there are problems fixing them may be as simple as using the method of this hint. It may also be necessary to reinstall them to the /Applications folder
Old 09-13-2010, 10:40 PM   #4
wonderwrench
This was an old thread BTW. CarlPo is running a Windows PC not an Mac.
He was asking how to move a complete windows install including both partitions on his raid0 setup to a SSD. If completed successfully which is totally possible, windows all programs and all data would be unaffected.
Old 09-14-2010, 10:04 AM   #5
rjs735
Virus? What I am not sick
rjs735's Avatar
I was wondering if a drive image might not work. The image deals with the data integrity regardless of whether the data is on a logical drive ( raid ) vs areal drive or even a logical partitioned drive.
I've never tried running a image on a raid array as I don't have any but maybe some one who has tried maybe able to answer.
Optorite CDRW WD 40GB
All systems are networked
